When will my 3.4L Die?
Old Aug 12, 2003 | 10:32 AM
stars1010's Avatar
Hit 121,000 miles this week. Still running strong but worried because I'm ganna put a bunch of miles on it in the next year while at school. I change the oil about every 2500 miles with high mileage Castrol just to be safe. So how long do I have? When will the 3.4L die? And by that I mean have to rebuild it or have some sort of major failure, not a tranny rebuild.
Old Aug 12, 2003 | 10:51 AM
ImportKILLER's Avatar
No real way for any of us to tell you. I do know there are 3.4s with WAY more miles than you that are doing fine.
2,500 on an oil change is a waste unless you are doing really severe duty with your car. I'm talking about letting it idle for long periods and extreme hot/cold weather. I push 4k on dino when I used to use it...oil analysis showed no problem with it. Synthetic now is 6-7k with good results.
Old Aug 12, 2003 | 05:13 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
my dad's lumina 3.1 L (basically the same motor) has 180K on it, and runs fine still.. the water pump went out once.. but other than that nothing has broken (knocks on wooden desk, cause if anything breaks , i'll be the one to fix it)
Old Aug 12, 2003 | 05:32 PM
MustangEater82's Avatar
I have 130k I am sure I am one of the top 5 of ragged on 3.4Ls in the world, waterpump hasn't even gone out, water pump died on my 2.8L at 110k, when I had it.
Only motor stuff I ever did was adjust the rockers(ticking) and that was with 110-115k on the motor at the time.
Old Aug 12, 2003 | 09:43 PM
mustangmuncher's Avatar
My 3.4l just died at 115,54x miles. Cam bearings went out due to low oil pressure. Looking to find a rebuilt 3.4l. Oh well, hopefully a rebuilt one will be a bit more spiffy than mine was.
-Eric
Old Aug 13, 2003 | 02:02 AM
gamer885's Avatar
Talking
My 95 3.4 has 152k on it and it still runs strong.
Old Aug 13, 2003 | 11:13 AM
GoghUA's Avatar
I am less than 800 miles away from 100,000 and the only problems I have had have been the starter and the alternator.
Hopefully my luck can continute.
BTW: How often should I tune up my car? The last time I did it was around 60-70,000 I think...
Later
Old Aug 13, 2003 | 04:10 PM
raider5.0's Avatar
i have 128,534 on my 95 3.4 and it runs rather good can still beat my friends 96 3.8 mustang.
Old Aug 14, 2003 | 11:47 AM
4thgenowner's Avatar
Both of mine died at 89k... its weird but they were good solid engines. Stock exhaust was nice too.
Old Aug 15, 2003 | 02:33 PM
kevin 2.8's Avatar
aww was hoping this was a thread about how to make one die...
Old Aug 15, 2003 | 02:52 PM
Tiago's Avatar
it will run forever if you take caer of it.
Old Aug 18, 2003 | 07:33 PM
MysticTeal 95 V6's Avatar
Mine has 103K miles on it right now... still feels fine to me Changed out the plugs/wires this evening actually, regular oil changes and checking the fluids goes a long way in the upkeep of a motor.
Old Aug 19, 2003 | 02:39 AM
kevin 2.8's Avatar
and oil pressure
Old Aug 21, 2003 | 06:52 PM
Bob's 01SLPSS's Avatar
Wink
My 3.4L has 150,700 miles on it and still running strong. Good Motor!!!
Old Aug 22, 2003 | 12:40 AM
mrrym1's Avatar
Thumbs up I correspond
I am a proud owner of a 3.4 L V6, and it has over 100,000 miles on it. The only things that I have changed on that car was a compressor (warranty) and an oil sensor (25.00). My car runs fine and I don't plan on getting rid of it any time soon. By the way its stock, just in case you were wondering
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Bxlt1
Sep 29, 2015 03:18 PM
KYWes
Sep 26, 2015 08:49 AM
