belt problem
Old Aug 11, 2003 | 06:56 PM
silzerz's Avatar
belt problem
I have a p600 charger that I cannot keep a belt on.It shreads the belt on one egde and it comes apart.It does not throw the belt off it just shreads it.I have changed the tenssioner,pullies,realined the pullies etc.Thanks for any help
Old Aug 11, 2003 | 09:53 PM
V-2 SQ Jes's Avatar
check pulley alignment with a straight edge, or better yet (if you can borrow one) a laser aligner. also check for bracket flex. grab the blower and try to flex it. i have seen them move 1/2"
Old Aug 13, 2003 | 08:09 AM
IDOXLR8's Avatar
You need to make sure your blower pulley is not walking. I would remove the blower belt and make there is no play in your blower pulley. If there is then I would say it is time for a blower rebuild.
If that is not the case you may want to look at getting a SD concepts spring loaded tensioner.
Old Aug 13, 2003 | 01:02 PM
ATMINF's Avatar
My fan shroud would catch the edge of the belt. I took the old dremal tool out and went to town on the shroud and it now works great. It has been years since I have the problem. Hope this helps.
Old Aug 14, 2003 | 05:17 PM
silzerz's Avatar
Thanks for the help guys.I think I will check the alignment again.I changed that when I put this belt on and I have just noticed the back off the belt is shreading this time.The last two belts shreaded on the front.I forgot to mention this is a 12 rib system.If that matters.Thanks again.
RUDEDOG
Parts Wanted
Apr 24, 2015 09:47 PM
warmeck
Mar 22, 2015 06:43 PM
grabbem88
Feb 23, 2015 09:41 PM
1LEThumper
Jul 14, 2003 12:45 PM
