Oil cooler questions....
Old Aug 10, 2003 | 02:26 AM
madwolf's Avatar
Arrow Oil cooler questions....
I'm swapping in a 94 (out of an auto car) engine in a 93 (auto) car. The 93 car has an oil cooler, but the 94 one does not. At least, it didn't come with the engine. The question is, should I install the oil cooler from the 93 on the 94 engine or not? The 93 engine has a cracked rod and I don't know if I want to reuse a part like this on the new engine...
Thanks!
Old Aug 10, 2003 | 02:58 AM
InjectedSS's Avatar
Re: Oil cooler questions....
Thanks!
hells NO!! get rid of that POS! i ripped mine out and dont regret it one bit! i heard tooo many horrer stories about them clogging up etc. just bypass it. all you have to do is run a hose from the bottom of the radiator to the bottom of the waterpump. basically just where the two hoses connected before. also you'll notice that the hoses are a lil bit bigger than the other so what i did was got one of those plastic hose converters that lets you go from one size to the other and i just tied the two hoses together with that.
youll like it much better cause youll be getting rid of more crap under the hood just like ripping all the tree hugger crap off the car youll have just that much more room under the hood to work
Old Aug 10, 2003 | 12:09 PM
madwolf's Avatar
Re: Re: Oil cooler questions....
Thank you!
Any more opinions? I'll take it off if it won't hurt anything for sure...
Old Aug 10, 2003 | 12:12 PM
Joe Brodman's Avatar
GP Moderator
I had an oil cooler on mine. Never had a problem with it, but it took up space and I never fully trusted it.
Sold it for $115 shipped on Ebay, w/ 93k miles on it.
As for the hose, I simply bought a hose that fit the radiator, and forced the other end onto the waterpump.....it will fit.
Old Aug 10, 2003 | 01:53 PM
Mtrhds94Z's Avatar
I wouldn't use it either.
That hose is 5/8 on one end, and 3/4 on the other.
'engine bypass hose' GM p/n 10197675
Also the Goodyear Hi Miler kit has it [even though it's for 95-7's]
2 lengths of heater hose, with a reducer coupling sounds fine.
Old Aug 10, 2003 | 05:54 PM
InjectedSS's Avatar
NICE theres a bypass hose sweet beauty now i gotta order that bish up learn something new everyday i tell ya!
good call on that one
Old Aug 10, 2003 | 11:51 PM
Dave Feerst's Avatar
I just used a 5/8 hose. I took my knife an chamfered the end that had to go on the 3/4 fitting and them pushed really hard....
Alot of people theake them off, I did but then I installed an oil to air cooler.
hey madwolf have you found dyno time to tune my car yet? I was expecting a call this week.
Old Aug 11, 2003 | 12:30 AM
sleeperz28's Avatar
I had my factory oil cooler cost me a motor. It clogged up resulting in loss of oil pressure. i now run a earl's cooler. Pretty much the same thing the older oil cooled porsche's ran. Its setup the same way as the radiator in the car just a little smaller. Dropped my oil temps anywhere from 40-60 degrees, then the water temp dropped about 15
Old Aug 11, 2003 | 10:57 AM
BUBBA's Avatar
One theory as to why my 97SS spun a bearing with less than 8K on the clock is that the SLP optional oil cooler clogged up with crap and
boogered my oiling. Just a guess, but when I looked at the cooler after engine removal there was actually metal shavings in there.
Of course, it's the chicken and the egg thing i.e, which happened first, the cam had knicked bearings and subsequently clogged the cooler, or the cooler was easily clogged after a period of normal break-in debris?
At any rate, is seems that when you change your filter, you should also clean the cooler or else you don't get all the crap out.
Just a theory.
Old Aug 11, 2003 | 12:02 PM
Don 97 SS's Avatar
I have one of those coolers. I like the idea of cleaning it, but can you? I check one out at a shop that was removed and it looked like it would be near impossible to clean it.
BTW, I hope we are all talking about the same factory oil cleaner and that there is not more than one oem type oil cooler out there. Like Bubba's mine was a factory option through SLP.
Old Aug 11, 2003 | 12:30 PM
gb95zconv's Avatar
Its a worthless POS....get rid of it. Get a real oil cooler if you want an oil cooler. I just used a 5/8 hose to bypass with.
Old Aug 11, 2003 | 12:37 PM
Don 97 SS's Avatar
While your opinion is clear, it is not very informative. Can you provide more information that led to your conclusion.
Old Aug 11, 2003 | 12:47 PM
JAFO1994's Avatar
So you just by pass the lines that run to the oil filter and leave the unit where the oil filter was or do you remove it. Could someone clarify for me. I don't understand how it clogs when it's just antifreeze running into and out of the block connected to the oil filter, unless I got something backwards.
Old Aug 11, 2003 | 12:55 PM
gb95zconv's Avatar
Simple.....its restrictive and does not cool the oil. It also collects metal debris during breakin. I removed mine and the engine runs no hotter.
Old Aug 11, 2003 | 01:02 PM
gb95zconv's Avatar
Remove it....its the oil passage that can clog not the water. The standard oil filter adapter is what the unit is connected to.....you will need some new blots to hold that adpter in place as the ones that hold it now are studded.
