locking header bolts
Old Aug 7, 2003 | 12:23 AM
lt4 fd's Avatar
the locks wont fit on some of the bolts since the bolt is sooo close to the header primary, do you have to shave them down or what?
Old Aug 7, 2003 | 12:58 AM
1982z28with18s's Avatar
Yep, just snip them to fit. To make it easier so you don't drop them you can tie fishing line or string around the clip and the other end to your finger so when you drop them you can get them back.
Old Aug 7, 2003 | 09:50 AM
BUBBA's Avatar
ARP 1" SS 12PTS.
Old Aug 7, 2003 | 06:48 PM
Bud M's Avatar
I had to grind on a couple of mine to get them to fit. I used my bench grinder.
Old Aug 7, 2003 | 10:42 PM
joefreeland's Avatar
try turning the bolt a 1/8 of a turn. I did that to some on mine and the locks fit right on. also you cant flip the Locks. The hex is offset to the notch on the locks. Sometime if you flip the locks they will fit. I had slp single cat 1 3/4 headers.
Old Aug 7, 2003 | 10:58 PM
Z95m6's Avatar
i had to grind only a few of mine but that is because one of my header tubes has had a modification and a weld was in the way. Mine are SLP single cats too
Old Aug 7, 2003 | 11:15 PM
EviLZ28's Avatar
Anyone have the new locks out there yet. I am gonna order a set from http://www.go-breslin.com/ They use an allen stud to lock the bolt into the head. Pretty cool set-up.
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
