Power steering gone??????
Old Aug 6, 2003 | 08:58 PM
naaz90's Avatar
I never had a problem with my power steering, but now its basically gone. It will kind of come and go. Fluid level is full and i dont see any leaking out of any lines. PUMP???
Also at the same time i am now leaking coolent. Its not much, but i can smell it and some of if it leaking onto the belt and being sprayed everywhere. I couldnt find any cracked hoses, they all seem fine, and non of the hoses are wet except for the ones that got sprayed. WATER PUMP?????? (there goes the opti)
Need help, it seems that some new problem arises everyday with this car.
Old Aug 6, 2003 | 09:05 PM
Red96Lt1's Avatar
I'm guessing that your coolant is leaking on the belt causing the belt to slip therefore seeming like your power steering is gone.
Old Aug 6, 2003 | 10:09 PM
naaz90's Avatar
i thought of that but there isnt all that much coolent leaking
Old Aug 6, 2003 | 11:09 PM
RENE95Z's Avatar
I second this. When my water pump was going, the coolant got on the belt and sprayed everywhere and it made my power steering seem like it was taking a dump. Fix the water pump, it doesn't take much to make the belt slip.
Old Aug 6, 2003 | 11:28 PM
TobyZ28's Avatar
I had exactly this happening too. Replace your water pump.... its bout to go
Old Aug 7, 2003 | 12:11 AM
LT1 PWRD's Avatar
I definitely had the same problem. My water pump was changed and everything was OK.
Let your car sit for a while and as the belt dries up your PS should come back until the belt gets wet again.
Change your Opti as well while your in there or you'll be back in there before you know it. Guess how I know all that!
Good luck
Old Aug 7, 2003 | 12:56 AM
m0nk's Avatar
Yup.. same problem here, odds are you really wount notice the leak, its usually small, just enough to get some antifreeze on your pullies and make them slip, I also had my alternator slipping, and the power would just drop to 12V once and a whille.... It was scary
Old Aug 7, 2003 | 06:37 PM
naaz90's Avatar
Thanks alot guys
Wheres the best place to get a water pump? Is there an online guide to replacing it?
Old Aug 7, 2003 | 08:19 PM
RENE95Z's Avatar
If you want to stay with the same type of pump rather than electric, just mosey on down to Autozone and pick one up. Reman's with a 1 year are about $50. Brand new with a lifetime are around $130.
mspennyhughes
Mar 1, 2015 03:50 PM
