Help, my radiator blew!!!
Old Aug 6, 2003 | 06:43 PM
blue89iroc's Avatar
My radiator now shoots fluid out of the side of it so I'd say I need a new one. Anyone have directions or know a good link for a radiator swap? Is it as easy as I think it is? Any time estimates? I am just putting a stocker in since I don't want to spend 600 bucks for a Be-Cool. Thanks a lot for the input!
Sean
Old Aug 7, 2003 | 06:41 AM
IDOXLR8's Avatar
I would just look in the for sale section for a used radiator. The radiator swap is pretty easy. All you have to do it remove the radiator cover, radiator and fans and radiator hoses.
Old Aug 7, 2003 | 07:19 AM
Red95Formula's Avatar
LS1Speed.com has some decent prices on new ones For a m6 its 400. Not as bad as a BE Cool!!
Old Aug 7, 2003 | 07:59 AM
blue89iroc's Avatar
Once the radiator cover is off and the hoses are removed, does the radiator just slip out or are there bolts to take out? Thanks a lot guys.
Old Aug 7, 2003 | 08:13 AM
I cant remeber exactly but I know there are about 6 clips that hold the condensor on and i think it just sits in the tray on the bottom and the shroud holds it down. I could be wrong its been a while since I took mine out.
Old Aug 7, 2003 | 09:23 AM
chevroletfreak's Avatar
I just replaced/repaired mine. The radiator just slides into place. The only thing that has to be removed is 3 bolts for the cover, disconnect the connectors to the fans, slide the fans off, and remove the hoses where they attach to the radiator.
I would HIGHLY recommend going to a radiator repair shop and have it repaired. The endcaps on our radiators are plastic and are prone to cracking. I had my endcap replaced with a NEW one from GM. The radiator was then cleaned & pressure tested for $70 total.
Be cool radiators can be had for $400 around here. A used stock radiator will run about $80-100.
Also, I have an M6. I had the endcap for an automatic equipt car installed. The reason I did this was so that I have a spare cooler for whatever I want to pump through it (brake fluid, power streering fluid, brake fluid, windshield washer fluid, etc.).
Good luck!
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
Pwilson59
Sep 3, 2015 08:47 PM
