coolant light STAYS ON help any1
Old Aug 6, 2003 | 10:53 AM
iCE's Avatar
iCE
My coolant light keeps coming on. I checked my radiator fluid and its full. And from the looks of it, the color is orange so I am guessing there is enough Dexi-cool or whatever its called. whats going on?
Old Aug 6, 2003 | 11:06 AM
kp2quik4u's Avatar
It's probably nothing more than the coolant temp sensor. Sometimes it gets crusted up and causes that light to come on. Nothing to worry about, unless you're overheating.
Old Aug 6, 2003 | 11:29 AM
TobyZ28's Avatar
I think he means the coolant level sensor, they're two temperature sensors, one for the PCM and one for the guage in your car...
Old Aug 6, 2003 | 11:45 AM
iCE's Avatar
iCE
well is there anything I can do to get that coolant light to turn off?
Old Aug 6, 2003 | 11:48 AM
94GrayV6's Avatar
My low coolant light just started coming a few days ago too, even though I've had it disconnected for months
Old Aug 6, 2003 | 11:52 AM
VegasZ's Avatar
The low coolant sensor is on the top right hand side of the radiator. It is cheap and easy to replace. You get much better access to it if you remove the battery. It is held onto the radiator by a clip which you pull out to remove it. If you disconnect the electrical connector to it, the low coolant light should go out. Some guys just leave it disconnected. I went ahead and replaced mine when it went bad.
Old Aug 6, 2003 | 02:35 PM
iCE's Avatar
iCE
do u happen to have the low coolant light sensor model # so I can order one? THX ((((1994 LT1)))
Old Aug 6, 2003 | 03:19 PM
VegasZ's Avatar
You can go to gmpartsdirect.com and search their catalog for the correct part number for your year. I ordered mine from them. They were the cheapest.
Old Aug 6, 2003 | 03:21 PM
fastcamz28's Avatar
Ice,
Check w/ any Chevy dealer; warning-the sensor is not cheap! Replaced mine about 3 weeks ago; didn't keep the box so I don't have the part #. EASY to change as noted above. WILL cure the "light on" thing.
Old Aug 6, 2003 | 04:42 PM
p/n 10096163 if it has two wires going to it.
Magenta_Hearts
Mar 29, 2017 08:54 PM
eazyZ
Mar 1, 2015 07:12 AM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
squarehead
Jan 15, 2015 07:02 PM
Black93lt1
Nov 21, 2014 07:30 PM
