Transmission Shift Table??
Old Aug 5, 2003 | 12:38 PM
bruecksteve's Avatar
A month ago I installed a new 4L60E and torque converter. I've already adjusted my shift points and TC lockup no problem. What I'd like to do is to soften my 1-2 shifts, they're very hard right now, I've already broken one transmission mount.
Which table to I need to adjust (or can I ) to reduce the harshness of that shift??
Old Aug 5, 2003 | 01:01 PM
madwolf's Avatar
Steve,
play with the line pressure offset tables for NORMAL.
Try decreasing all those values by about 25%-30% and see if you like it better like that. Or more if you want even softer shifts.
Old Aug 5, 2003 | 01:04 PM
Thanks Ion, I should have asked you first!
Old Aug 8, 2003 | 11:18 PM
LWM's Avatar
LWM
Originally posted by madwolf
Steve,
I'm sort of fighting the same beast. My 1 - 2 and 2 - 3 shifts are too harsh at very light throttle applications. I've already gone 30% down on the line pressure offsets, both normal and performance tables, and ... I've not noticed much difference.
A ? ... Can you put a negative number in at Zero throttle position?? How will that affect things?? It's really annoying to get a hard shift just after you let off the gas and are coasting ... sigh ... the price of performance.
I don't really like putting really bizzare numbers into my PCM without at least some outside information, and or consultation.
Thx for any help
LWM
DirtyDaveW
Dec 1, 2016 05:37 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
Apr 16, 2015 09:57 AM
jackpawt883
Feb 26, 2015 09:04 PM
