About Trans-Am rear end
Old Aug 2, 2003 | 06:38 PM
FRAN_Astur's Avatar
Has a 78 Trans a limited sleep rear end from factory?
I can buy a 78 trans rear end complett, with brake included for a little money (about 60$), but it is not a limited sleep it is not interested me.Thanks.
Old Aug 4, 2003 | 09:29 PM
CoryM's Avatar
Not all trans-am were posi. To check get both wheels off the ground and turn one wheel. The other wheel should spin in the same direction. If both wheels turn the same direction it is posi. If only one wheel spins or they spin in different directions it is not posi (or the posi is worn out)
CoryM
Old Aug 4, 2003 | 09:58 PM
MadMike's Avatar
Most trans am's also had 2.41 rear gears. Not a big deal when the car had a torquey 400 in it. But in a heavy small block camaro that gear will kill any acceleration potential.
Old Aug 6, 2003 | 04:54 PM
Damon's Avatar
The USUAL reason for buying a T/A rear of that vintage is becuase some of them had rear disc brakes (that the Camaro of that era never got). It was a performance option and so I believe all disc-brake rear ends came with posis, but don't quote me on that.
For sure, anything that old is probably in need of a posi rebuild or replacement anyway.
Old Aug 7, 2003 | 03:33 AM
FRAN_Astur's Avatar
Thanks for all responses.Fran.
Old Aug 7, 2003 | 09:04 AM
406TA's Avatar
My friend just bought an '80 T/A and I thought for sure it would have a posi rear. Guess what, it didn't. For some reason I thought all 2nd gen. T/A's had posi.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
