Is this an SLP lid, or what?
Old Sep 12, 2002 | 03:37 PM
Desolate_Flux's Avatar
Post Is this an SLP lid, or what?
Check the link -
http://www.headrushperformance.com/j...dsc001222.html
I drive a 2002 SS. Is this a 'stock' lid, or an SLP lid? I dont see SLP mentioned anywhere on it.
I've heard this lid sucks. Opinions?
Is it worth me getting a 'better' lid, for better performance and fuel economy? Which would you recommend if so? Or is this lid just fine?
-2002 Red Camaro SS
Chesapeake, Virginia
http://www.HeadRushPerformance.Com
Old Sep 12, 2002 | 03:55 PM
ChrisFrez's Avatar
Post
Yes, absolutely - does it say blackwing on it in the lower right hand corner?
I believe this was part of their 345HP package Y2Y options on the car.
Chris Frezza / CamaroZ28.COM UBB Admin
2002 Camaro SS #1931
1995 Supercharged Camaro Z28
2001 Buick Regal GSE
Old Sep 12, 2002 | 05:01 PM
Post
I dont see any mentioning of "Blackwing" anywhere on the thing. Is that how you know if it is an SLP or not?
Any other opinions on how I can tell the difference for sure?
-2002 Red Camaro SS
Old Sep 12, 2002 | 05:42 PM
Camaro ChriSS's Avatar
Post
That is definitely NOT an SLP lid, nor part of any 345 hp package. That's the GM lid with the air silencers in place on a 2001-2 Camaro (judging by the lack of an EGR.
That is a GM stock lid and not the optional one.
2000 Pewter SS #C161
SLP Dual-Dual, Bilstein suspension, Eibachs, 21mm/35mm swaybars, GMAF
SLP CAI w/lower plate, !EGR, Direct-Flo, SLP STB, Ported TB, ASP Crank pulley
SLP/AAM Diff. cover, SY3500, SLP LS6 Intake, Powershot, MSD wires, NGK's,
BMR Boxed LCAs, BMR PHB, BMR SFCs, G2 DSL, Nitto 555R, Heavy Lead Foot...
http://community.webshots.com/user/murlynd
Old Sep 12, 2002 | 08:05 PM
O1Z's Avatar
O1Z
Post
That's the regualr POS intake.. it's the same one that came on my 01z.. go.. right now.. and buy a new air box lid! GO! My god.. you can feel the horse power that new lid will give you. You'll never again get such a power boost for under 200 bux.. NOW.. GO BUY ONE!
Get a K&N filter too.. make SURE you get the little foam gasket that sticks to the lid, k&n should give it to you with the filter, if they don't, don't use the new lid and call K&N. they'll send you the gasket.
Bart
Old Sep 12, 2002 | 08:11 PM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Smile
Camaro ChriSS & 01Z, are right on the money, it is the stock POS lid with the air baffels in the back, it was also on my 2001 Z28 from the factory.
SteveC
Old Sep 12, 2002 | 09:08 PM
ChrisFrez's Avatar
Post
My bad - I didn't look close enough. Those new blackwing SLP boxes look pretty factory. Sorry bout the misinformation.
Get yourself an LS1 Motorsports Lid and be done with it
Old Sep 12, 2002 | 09:33 PM
psychocabbage's Avatar
Talking
and I would suggest a Holley Powershot instead of the K&N as it fits perfectly from what I am told while the K&N requires that foam piece.
I personally will be getting a Whisper Motorsports Lid..
Psycho Cabbage
2002 Camaro Z28
(6 sp) Bone stock
Webmaster for RaceHer.com
Check out the current polls and vote!
by the prìcking of my thumb, something wicked this way comes
-Traded in- 1995 Camaro Z28 (A4 (#6 I might add!),ES tranny mount and torque arm bushing,SLP CAI,ASP 34% Underdrive,Strange 3.73's (shredded Auburn),1LE alum driveshaft & intake elbow,Yokohamas AVS Intermediates,160-stat,MAF screen removed, HPP+(for shift points only),Borla Y-pipe, Flowmaster Force-II catback, Gutted Cat, Airlift Airbag, !TB Bypass, J&M LCA's, Bosch Platinums, Moroso BlueMax Wires, Free RamAir, Meziere Electric H2O pump, MAC 3point STB, BMR Panhard, SCR SFC's
Just installed:Nu-tek Heads (mild port) and Comp Cams 1.6RR's! New track and dyno #'s to follow!
best 13.44 @103.26
0-60ft 1.96
270 RWHP/296 RWTQ
0-60MPH 4.8sec
1987 Porsche 944S (waiting on LT1 mod)
Old Sep 13, 2002 | 05:04 AM
SteveC's Avatar
Smile
psychocabbage;
I have a post 2000 vehicle too, consider getting the SLP airlid instead, it is the only one I know of that has the air pump hose connection to the airbox, it really makes the lid look like a stock setup, and the graining of the plastic blends in perfect with the rest of the airbox.
I have the Holly powershot airfilter, and it fits like a glove (no VW's for me ).
JMHO
SteveC
Old Sep 13, 2002 | 09:05 AM
Talking
SteveC, the main reason I wont get the SLP box is becuase of the fitment issues some people have. I read about it on their website when a user posted his issues. He went to SLP in person and showed them his airbox and they told him that it was because some are made better than others. They didnt replace it or anything. I personally feel that he was not treated properly. I double checked this at the SLP Customer Appreciation Day in Ennis TX. There I looked at every lid possible. Many of the SLP lids did show the same issue as was described and pictured in the post (The front of the lid was not flush and the right and left edges were kind of bending upwards). I witnessed at least 4 of the SLP lids at the car show there with this. MTI lids fit perfectly as did the LS1 Motorsport lids. I am wanting the Whisper lid because I am going to be getting a blackleather and carbon fiber MOMO shift **** and I want the lid to be of the carbon fiber look as well. I like the idea of stock looking but I dont want the **** to be the only bit of carbon fiber look in the car so the lid will tie the two together... Also, I use a Quake 3 etched glass look sticker on my car and I am thinking that on the smooth surface of the carbonfiber look lid, it would stick better if I put one underhood.
Old Sep 13, 2002 | 09:46 AM
Post
Why would they make this stock lid suck so much, the one that I currently have in the picture (my origional post)?
Why not spend an extra 10 cents and make it decent, like these aftermarket ones?
What is the least expensive lid I could use to replace this one, that I'll notice a good performance gain and have no issues fitting on my 2002?
Thanks!
-2002 Red Camaro SS
Old Sep 13, 2002 | 11:08 AM
Post
<font face="Verdana, Arial" size="2">Originally posted by ChrisFrez:
</font>
Everyone has an off day now and then Chris...
Get the Direct-flo unit from LS1 Motorsports. Watch for a GP on it or get one used in the classifieds. There is often one for sale (check LS1.com too).
The stock one is designed as it is to reduce noise (for federal drive by noise control and for wimpy drivers) at the expensive of airflow. It's likely also done to specifically give the Vette a better edge.
Old Sep 13, 2002 | 11:29 AM
SteveC's Avatar
Smile
psychocabbage;
Sounds like you did alot of homework on this, I must have been lucky, my SLP lid seated properly upon installation.
Either way, you will not go wrong with the MTI product.
It sounds like you have a great car in the making.
SteveC
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
tommalcolm
Sep 11, 2015 03:39 PM
rideordie
Sep 7, 2015 08:22 AM
