Quick! My bellhousing wont detach from my block (T56)
Old Jul 30, 2003 | 07:44 PM
Rodrigues's Avatar
I pulled the shift fork, removed all 6 bellhousing bolts and it wont budge! What did I do wrong, I have pressed so hard and nothing.
Old Jul 30, 2003 | 08:14 PM
Z95m6's Avatar
if it moves back and forth but wont come off it might be the inspection shield catching the flywheel ask me how i know. If it is just stuck on the aligning pegs try tapping the bellhousing on the side with a hammer right by the pins.
Old Jul 30, 2003 | 08:17 PM
Rodrigues's Avatar
It wont seperate from the block . Alright, I will try that.
Old Jul 30, 2003 | 08:44 PM
burnemonm1's Avatar
next step get the 3ft. pry bar if you have a gap at all, be 100% that all the bolts are out first. I have had this problem on other cars before.
Old Jul 30, 2003 | 09:29 PM
95 Z/28 LT1's Avatar
Super Moderator
When I do it, I will take the tranny away from the bellhousing first, then pull the bellhousing.
I take it you have your shifter off and the tranny crossmember and torque arm detached?
Old Jul 30, 2003 | 09:39 PM
PatriotTA's Avatar
When I did it, I dropped the trans, then the bellhousing. Make sure all of the bolts are out and that the inspection cover is off as well. The inspection cover is held on by 4 (I think that's the number) bolts and its that thin stamped steel piece on the engine side of the bellhousing. I had to give my bellhousing a few love taps with a hammer and then used a pry bar to get it seperated, then shook it like crazy til it came off in my hands. HTH
Old Jul 30, 2003 | 10:43 PM
Rodrigues's Avatar
Alright, my trans was originally just stuck to the block, now we tried for hours to get it out and its catching on the flywheel and tunnel. Its digging a groove in the tunnel and catching on the flywheel or something. Im getting so frustrated, i stopped for the night.
Sergio
Jan 27, 2016 04:27 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Duke
Jul 31, 2002 05:13 PM
