at the track, do you?
Old Aug 30, 2002 | 11:00 AM
psychocabbage's Avatar
Talking at the track, do you?
Ice down the intake?
How about remove the air filter completely?
Just wondering what are common things that are done at the track with LS1 cars.
Psycho Cabbage
2002 Camaro Z28
(6 sp) Bone stock
Webmaster for RaceHer.com
Check out the current polls and vote!
by the prěcking of my thumb, something wicked this way comes
-Traded in- 1995 Camaro Z28 (A4 (#6 I might add!),ES tranny mount and torque arm bushing,SLP CAI,ASP 34% Underdrive,Strange 3.73's (shredded Auburn),1LE alum driveshaft & intake elbow,Yokohamas AVS Intermediates,160-stat,MAF screen removed, HPP+(for shift points only),Borla Y-pipe, Flowmaster Force-II catback, Gutted Cat, Airlift Airbag, !TB Bypass, J&M LCA's, Bosch Platinums, Moroso BlueMax Wires, Free RamAir, Meziere Electric H2O pump, MAC 3point STB, BMR Panhard, SCR SFC's
Just installed:Nu-tek Heads (mild port) and Comp Cams 1.6RR's! New track and dyno #'s to follow!
best 13.44 @103.26
0-60ft 1.96
270 RWHP/296 RWTQ
0-60MPH 4.8sec
1987 Porsche 944S (waiting on LT1 mod)
Old Aug 30, 2002 | 11:27 AM
'01BlackZ's Avatar
Post
Just put a bag of ice on the intake manifold for however long you want.
As far as the air filter, i keep mine in. There might be some people that take theirs out, but with the FRA, i need the filter. I've seen all the sh*t that gets stuck in the filter.
As far as other things, you can drop your tire pressure a bit if you have street tires.
Have about a 1/4 tank of gas, take out your spare and jack, i also check the oil just to make sure i have enough. Clean your air filter( i just knock the big stuff outa my K&n)
**Onyx Black 2001 Z-28 w/ GFX**
"I hate rattles"
Performance Mods:G2 air lid, MAF, skip shift eliminator, Hypertech 160 Powerstat, FRA,k&n, SLP Hi flow Bellows, SLP Air Temp Module, Lou's Short stick, Corsa Premier catback, Mobil 1.
Chassis/Suspension Mods: G2 springs, G2 SFC's, G2 3pt STB, G2 LCA's.Appearance Mods: RK sport carbon fiber letters/Z28 overlays & Nose Badge, Red Calipers W/ Black Brackets, 18x9.5 z06.
Drivetrain Mods:TA Girdle w/ stud kit, redline fliuds.
My Z-28
[This message has been edited by '01BlackZ (edited August 30, 2002).]
Old Aug 30, 2002 | 01:28 PM
Post
My friend would usually take his out for the passes he makes then put them in for driving.
When you consider that most tracks are not full of most of the crap you find on city streets it makes some sense.
I just wasnt sure if people had tired it or if anyone has any horror stories.
As for icing the intake, I used to do it on my LT1 but wasnt sure if it was bad to do it on the LS1.. ya never know till ya ask!
Old Aug 30, 2002 | 03:38 PM
nikkev's Avatar
Cool
A few things I do:
-Check the oil.If it's even a TINY bit low I fill it.
-Try to run the gas to to a 1/4 tank or less.
-Lower the PSI in street tires to around 24psi or so.
-Let the car cool down before the first run.
-When you get to the staging lane do a SHORT burn-out NO SMOKE.All you want to do is clean the crap off the tires.
-Without drag radials you will need to feather the throttle off the line.
-Take out the driver's floor mat or at least pull it back out from under the gas pedal.
-Slide the seat forward so that you don't have to stretch to put your foot all the way to the floor.
-When you start and get traction,floor the gas pedal ALL THE WAY and do not let up until you cross the line.
That's about all I can think of that I do.Good luck man.
Kevin
Edit: I don't take out anything from the car.I want to know what it'll do in completely stock trim.
1998 Black Z28 A4
-------1/8-------
8.548 @ 83.64 MPH
Pics
Camaro/Firebird Birthday Bash
[This message has been edited by nikkev (edited August 30, 2002).]
Old Aug 31, 2002 | 08:41 AM
BlackHawk T/A's Avatar
Post
Actually, me and some guys on LS1.com were talking about running temps, and we agreed that the LS1 likes it hot. Every one there said their best times were run back to back when they didn't let the car cool down. The LS1 is designed to run the block at 210 and the heads at 187. This is how it avoids detonation and makes more power when its warm.
However I am only talking about coolant temp. Cooling your intake would lower IATs and possibly make a little more power, although I haven't seen anyone try it.
1983 Monte Carlo, 307 Stroker, TH350, 3.73 10-Bolt - SOLD 8/19/02
Future F-Body Owner
[This message has been edited by BlackHawk T/A (edited August 31, 2002).]
Louey
Pacific
Oct 1, 2015 12:37 AM
NewsBot
Sep 16, 2015 10:30 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
Louey
Pacific
Sep 1, 2015 07:19 PM
Louey
Pacific
Aug 25, 2015 01:53 AM
