how do i remove the E brake handle
Old Aug 25, 2002 | 03:45 PM
venomcure98's Avatar
Angry how do i remove the E brake handle
Im trying to get my center console off so i can install my new shifter and i need to know how to get the emergency brake handle off. It is being held on by a roll pin screw and i have no clue on how to remove it. Any help would be appreciated.
Old Aug 25, 2002 | 03:52 PM
nikkev's Avatar
Unhappy
From what it looks like it's a rivet and you have to drill it out.Then when you go to install it again you'll have to use a screw.
Kevin
1998 Black Z28 A4
-------1/8-------
8.548 @ 83.64 MPH
Pics
Camaro/Firebird Birthday Bash
Old Aug 25, 2002 | 05:43 PM
Rickm's Avatar
Post
Don't have to pull the handle off to Get Console off or to install new shifter.
Rick
'65 Malibu SS - 280rwhp/330ftlbs
'98 Camaro Z28 - 318rwhp/334ftlbs - Sold 7-18-02
'02 TransAm - Brand new No dyno Yet
D-flo lid, GMS, Hotchkis STB, Hurst B+
Bat-CaveOnline
Old Aug 25, 2002 | 05:49 PM
96SFLZ's Avatar
Post
What Rick said, you don't have to remove it. Just pull it straight up(as far up as it'll go) and you shouldn't have much trouble getting the console over it.
Aaron
Black '96 Z28 *sold*
¼- 12.97@107.2
SSM '02 Z28
Pro 5.0, FRA, MTI lid
¼- 13.21@108.2
Old Aug 25, 2002 | 06:17 PM
6speedZ28's Avatar
Post
Yep, what they said, I never had any trouble getting the consol off on my '97...just pull it straight up.
1998 Camaro SS A4 #2,515 OF 3017
NBM w/ grey leather
T-tops, all GM options
MODS:
-SLP dual-dual (came with car)
-Hypertech 160 thermo
-SLP Lid w/ K&N and smooth air bellows
**1997 Z28 M6...yes it was modded. Totalled by a girl who couldn't stop for a stop sign on 4-18-2002
Old Aug 28, 2002 | 10:59 PM
Haw'n Z's Avatar
Post
Whatever you do, do not remove the e-brake. If you need to make it at a 90 degree angle lift the console gently as much as possible. You should be able to see a gear at the base of the brake handle. This is were it ratchets up and stops. You will see a spring loaded block that stops the brake hand at the top of its travel. Lift the handle slightly to get a little slack, and with a long screw driver pop it off the gear and pull the handle up to almost a right angle or just enough to get the console off. Be careful not to break the shifter boot while making this move, if you break it it will cost about $45. Make sure you remove the wire connections and the console should come straight up and off. LOL
Old Aug 29, 2002 | 06:59 AM
ChrisFrez's Avatar
Post
You definetly do not need to remove the E-brake to install a shifter. Check out this install documentation at Install University:
http://www.installuniversity.com/ins...er_install.htm
Chris Frezza / CamaroZ28.COM UBB Admin
2002 Camaro SS #1931
1995 Supercharged Camaro Z28
2001 Buick Regal GSE
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
