opti spark, installed 2 BRAND NEW GM units in 4 days!!! READ!
Old Jul 24, 2003 | 07:01 PM
East Coast Perf's Avatar
Angry opti spark, installed 2 BRAND NEW GM units in 4 days!!! READ!
Well, we have installed two brand new GM opti spark units in the past 4 days on my blown LT1 TA, after the 2nd unit I decided to pull the 1st one apart and find out what all the rattling was about.
Rotor and cap were worn, rotor was blown apart (no contacts left- dangling in bottom of unit) checked timing cover alignment with block-good, dowel pins are in place and square, cover is not cracked around dowel pins, no problems there, this is the same timing cover that we have been running for three years (brand new GM) motor is brand new, custom COMP cam new thrust plate and cloyes true roller chain (E-water pump).
so.............do ya guys think the cam is walking and pushing the rotor into the cap, heating it up, melting, then destroying the rotor?
Bout ready to call bob bailey and have him send us some LS1 coils.....
<K>
Old Jul 24, 2003 | 07:03 PM
Question blown apart (rotors)
has anyone had a similar problem? we've worked on HUNDREDS of LT1 cars in the area, and have NEVER had a problem as this!!!!!!!!!!!!!!!
Old Jul 24, 2003 | 07:04 PM
turbo_Z's Avatar
did you cut the dowel pin down on the cam? for some reason they are too long and ruin opties... i suspect this is your problem. the opties dont just die but they break like you are describing. why comp keeps putting in dowel pins that are overlength i dont know but i have emailed them about it before only to naturally get no response back.
JordonMusser's Avatar
West South Central Moderator / Special Guest
you check the dowel pin length, and that the right cam bolts were used?
you may try shimming the opti slightly.
Old Jul 24, 2003 | 07:11 PM
Arrow bolts and dowel pin
? has anyone here had this problem?
we know all about the long dowel pins, and ALWAYS have to slide hammer them out and recut them, this one didnt come with a dowel (custom comp piece) so we installed a stocker, (maybe comp didnt drill the blank deep enough? Hrm, sounds like the dowel could be causing the problem?
Every time I instal a new opti, we make sure that the unit seats FLAT on the timing cover, and when it seats, it clicks into place, so no pressure is put on the unit (internally) this one did just that and showed no sign of pressure...
G*D DAYUM PIECES OF S**T!!!!!!!!!!!!!!!! Did someone aleready assainate the engineer of this thing?
Old Jul 25, 2003 | 04:25 AM
NJLT1SS's Avatar
When I installed my XE 230 durng my cam/head swap, I checked the dowel pin lenght next to the stocker. Wouldnt you know it, it was a good bit longer, and Im sure enough to cause opti problems like you are having right now. What I did was mark the lenght of the stocker on the Comp Cam, cover the new cam in the bag that it was wrapped in from Comp Cams, and cut of the extra lenght of the pin off with my Dremel and cut off whell. The Dremel whizzed through it in about 20 seconds. I would devinitly check out the dowel pin lenght. If you have to cut it on the motor, it should be easy to do once you have the timing cover off.
Nick
Old Jul 25, 2003 | 09:40 AM
Fast S/C '94Z's Avatar
I switched my vacuum lines on my opti and it melted the rotor. The vacuum must of sucked the cover in till it rubbed on the rotor.
Old Jul 25, 2003 | 11:09 AM
Unhappy nonoptimum spark
got it taken care of[
QUOTE]I switched my vacuum lines on my opti and it melted the rotor. The vacuum must of sucked the cover in till it rubbed on the rotor.[/QUOTE]
thats a good one!!!!!!!!!! being this thing barely pulls any vacuum, I wouldnt think thats our problem interesting though!
alliance12364
Mar 6, 2015 04:39 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Catmaigne
Dec 25, 2014 12:16 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
