HAL QA1 front shocks/V6 springs??
Old Jul 24, 2003 | 01:41 PM
CDE's Avatar
CDE
Ive been told that the adj HAL's wont work with V6 front spring set up, that you have to buy HAL front springs as well. Is this true?
Clint
Old Jul 24, 2003 | 02:27 PM
You can not use any stock 4th Gen springs with the QA1/HAL shocks, unless you modify the stock spring seat. Rob/Shoebox and I have worked out the details:
Rob/Shoebox's pic of modified stock seat
My drawing of seat mod
Old Jul 24, 2003 | 02:29 PM
sssalah's Avatar
The hal shocks are a little bigger in diameter than the stockers, and there springs are a little smaller to fit over the hight adjusting ring.
You can fit a stock style spring on the hal, but you'll need to modify the stock spring seat to make it fit over the bigger hal body. Hal springs are a straight forward fit.
Old Jul 24, 2003 | 06:10 PM
CDE's Avatar
CDE
Thank you guys for your time and info. That was a big help and will save me alot of time from trial and error.
Clint
Old Jul 24, 2003 | 06:24 PM
CDE's Avatar
CDE
Another ?? for ya. Is the HAL Gen-F front shock something new? It says it is based on the QA1 Proma Star Al, but designed for F-bodies. Any info on this shock?
Clint
Old Jul 24, 2003 | 06:36 PM
Clint
They have been around for several years. Basically that is telling you that they gave the shock the correct mounting features to fit on the F-body.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
KYWes
Apr 3, 2015 07:59 PM
ModdedNerd
Dec 25, 2014 05:51 PM
