Power adders for 89 350 TPI
Old Jul 24, 2003 | 01:28 PM
DanTheIROCMan's Avatar
I'm interested in maybe spending a thou or 2 on my 89 to give it a little more go beyond 1st gear when it tends to run out of steam. I'm mainly interested in bolt on stuff that I can do myself (highly mechanically inclined). No gear swaps at this time. Looking for suggestions on maybe some cams, TPI stuff, etc..
I've already got a high flow cat and flow-master 3 chambers.
Any ideas/suggestions would be appreciated.
Old Jul 24, 2003 | 01:31 PM
IrocinthatZ's Avatar
runners,intake manifold,throttle body(with airfold),heads,headers,you could put a supercharger on it i would recommend a ATI Procharger if not that a vortech. just a few little basic things.
james
Old Jul 24, 2003 | 01:48 PM
Sorry, forgot to mention not supercharges for now as well. Looking for recommendations on maybe some better heads and headers as well. Keep in mind, I want the car to remain street legal and it will be a daily driver, but I'm just trying to get more pull through the entire RPM range, without sacraficing too much (if not any) of my low end grunt.
Old Jul 24, 2003 | 04:53 PM
89'Formula's Avatar
I would recommend the ZZ-9 or if you would like to go a little more aggresive the ZZ-409. The specs of the cam are on http://www.tpis.com/. If you were to match either of the cams with a set of aluminum heads that came on some of the TPI motors and do a good job porting you could make some real good power. If you were adding heads and a cam you would want to add a new intake, aftermarket LongTube runner intakes are expensive but you could have a 12sec N/A car with gobs of torque and you could always add stuff like a converter, prom, etc to increase your gains. Good luck and I hope that helps a little. Keep us informed on the progress and/or decisions you make.
daves91z28
May 12, 2016 06:19 AM
linz
Oct 22, 2015 07:59 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
4586
Dec 6, 2014 05:20 PM
