FelPro intake manifold gasket part #
Old Jul 24, 2003 | 11:38 AM
Hyperspeed97z28's Avatar
Whats the FELPRO part # for the intake manifold gasket... gonna start the bastard this afternoon.... along with that gasket needed, Im gonna get HIGH TEMP COPPER RTV... anything else i should get besides the fuel line tools ?
Old Jul 24, 2003 | 11:44 AM
madwolf's Avatar
Keith,
I've done the intake fix and pulled the intake a few times without having to disconnect the fuel lines. Might want to try that before you disconnect them.
Other than what you mentioned, I used some very fine sand paper to remove gasket material from the block and lots of carb cleaner to clean the intake.
I also changed the throttle body gasket and did the throttle body bypass at the same time.
Don't know if this is a Felpro part number, but LS1 speed has the needed gaskets and their part number is: FEL1284
Old Jul 24, 2003 | 11:47 AM
I got my gaskets at Autozone. MS95580 for the Felpro manifold set.
Old Jul 24, 2003 | 11:50 AM
ION and ROB,
Thanks for the quick reply's
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
ModdedNerd
Dec 14, 2014 10:28 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
