Havng trouble taking shifter off
Old Jul 22, 2003 | 03:07 PM
ninjatertl's Avatar
From: In the Sewer with the Splinter & the other turtles
Unhappy Havng trouble taking shifter off
I have a B&M Ripper shifter and need to remove it but it seems to be stuck. I took off the 4 corner bolts then i cant seem to take it off! Does it slide off or pop up off? I cant remember if there some type of silicone under the base to keep it still, any suggestions?
Old Jul 22, 2003 | 03:08 PM
KCFormula's Avatar
Take a flat head screwdriver and pry on the edge of it gently. IT should pop right off but might be stuck due to RTV between the shifter and the tranny.
Old Jul 22, 2003 | 03:16 PM
PatriotTA's Avatar
I used a mini-pry bar. There are a few factory pry spots cast into the tranny. Find the pry spot (I do it on the left side) and pop it right off.
Old Jul 22, 2003 | 04:15 PM
Fastbird93's Avatar
I wouldn't pry with anything sharp, as you may nick up the metal. Take a rubber mallet and give her a smack. Should pop loose.
Old Jul 22, 2003 | 04:38 PM
KCFormula's Avatar
I wouldn't hit it too hard from the side or else you might crack the plastic cup inside there.
Old Jul 22, 2003 | 04:45 PM
ninjatertl's Avatar
Thumbs up
Thanks guys. i used the other side of a hammer at the "pry" point and popped right off!
Z95m6's Avatar
i would try tapping on the side of the base lightly with a hammer that should break it loose.
DirtyDaveW
Dec 1, 2016 05:37 PM
PROJECT X
Apr 17, 2015 12:13 AM
Apr 16, 2015 09:57 AM
BigWil
Mar 29, 2015 12:24 PM
Darth Xed
Jul 1, 2002 03:22 PM
