Help, SES after SLP Fan switch install.
Old Aug 18, 2002 | 02:22 AM
GC456's Avatar
Unhappy Help, SES after SLP Fan switch install.
I dont really understand what happened. I hooked up the manual fan switch and it works great. The car runs great and everyting works. The only problem I ran into was that I blew the fuse for the Cig Lighter/Accessory. I replaced the fuse (all other fuses were ok) But the SES will not go off.
How can I reset my PCM? I disconnected the battery after I replaced the fuse with no luck.
Thx
'98 Artic White Z28 M6
Free Mods! LS1 Lid, Smooth Bellows, Granatelli MAF, 160 Stat, MAC Headers and Offroad Y-pipe, Flow Cat-back, B&M Ripper.
The following BMR Crome Moly Suspention parts ***STB, LCA, Torque Arm, Panhard Rod***
Regular BMR parts *Swaybars, SFC*
http://cardomain.com/id/gc456
Old Aug 18, 2002 | 04:07 AM
#2's Avatar
Post
if the fan switch isn't compatible with OBDII cars it'll throw the SES light.
Old Aug 18, 2002 | 09:51 AM
9T8W66's Avatar
Post
I've had mine in for over a month and had no problems, maybe you installed it wrong?
NBM`98 Formula 6spd,Ram air hood, Hurst billet,FRA,EGR mod,cags delete, Flowmaster catback.
Old Aug 18, 2002 | 10:08 AM
2001NBMZ28's Avatar
Post
To reset the PCM:
Turn key on, don't start car
Pull PCM BAT and PCM IGN fuses in eng compartment
Wait a few minutes
Turn ignition off
Replace fuses
Did you start the car with the switch on? I've heard sometimes that'll throw a code, but I'm not sure.
A4 (3.42)/Whisper Lid/Corsa Catback/FTRA/BMR STB, LCA's, APHR/160+Tstat/SLP Fan Switch/HPP3
Old Aug 18, 2002 | 11:44 AM
GC456's Avatar
Post
Thx for the help guys.
I really dont see how I installed it wrong though, if I did it seems like alot of stuff wouldnt work.
I did however permently remove the cigarette lighter in order to mount the fan switch there.
I will try to reset the comp today and if it still throws a code I will take it to the Zone!
Old Aug 19, 2002 | 11:53 PM
kclarson's Avatar
Post
Hey,
It is giving the SES light because the PCM monitors the state of the 2 fan control output signals. When you turn on the manual fan switch the the PCM signal gets pulled to ground. The PCM signal should see at least 5 volts or the SES light will go on.
I have a solution to this problem also. It involves adding 3 resistors and 2 diodes to the manual switch mod. I can send you a wiring diagram if you like. Just send me an email.
Courtney
Also check out this link for more info.
http://web.camaross.com/bb/Forum1/HTML/108636.html
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 10:44 PM
MYT30TH
Jul 28, 2002 08:47 AM
