how could i tell if this cam is a LT4 hot cam??
Old Jul 21, 2003 | 01:57 PM
86T/AWS6's Avatar
Arrow how could i tell if this cam is a LT4 hot cam??
I recently bought a cam from another board member...i had teh part number ready but there isnt a part number stamped on the cam...He also threw the box away to the cam....There are numbers stamped on the end of the cam, could someone with a hot cam out of their car please look at the end of theirs and tell what the numbers are stamped on yours??? i just wanna make sure i got what i payed for...thanks guys!!!
Old Jul 21, 2003 | 02:03 PM
turbo_Z's Avatar
well whats stamped on your cam? i dont have a hotcam but the numbers might tell somethin.
Old Jul 21, 2003 | 02:04 PM
faded93bird's Avatar
342 99R
586 FM49 with a green dot
Old Jul 21, 2003 | 02:18 PM
Mtrhds94Z's Avatar
Originally posted by faded93bird
342 99R
I believe the 586 denotes the last 3 digits of the hotcam GM p/n...
Old Jul 21, 2003 | 10:34 PM
86T/AWS6's Avatar
my cam has "110 97L" stamped on teh end of it....please dont tell me i got ripped
Old Jul 21, 2003 | 10:43 PM
Blue96z28's Avatar
i don't know, but wanted to add that i had a CompCams 270h in a 85' 350 SB, and it had 270h stamped on the end of it, so maybe this could help, but i doubt CC makes one w/ that #.
Old Jul 21, 2003 | 10:53 PM
86T/AWS6's Avatar
someone please help me here...im getting nervous....
Old Jul 21, 2003 | 11:00 PM
there are two sets of numbers on my cam. I beleive that the top/or 6 digit number is a lot/ or product # the lower 7 digit code is the cam id #
Old Jul 21, 2003 | 11:21 PM
Fast S/C '94Z's Avatar
if you have a micrometer, you can check the lobes of the cam
Old Jul 21, 2003 | 11:27 PM
86T/AWS6's Avatar
the only thing is a micrometer wont tell me the duration, or LSA....lift is lift....alto of cams have the same lift as teh HOT cam...does an LS1 cam look alot different? I found in pace performace a LS1 ASA cam that ends in teh parts number "110"...does an LS1 cam have the mechanical fuel pump lobe and a gear for a distributer???
Old Jul 21, 2003 | 11:50 PM
JeffK95Z's Avatar
call your local chev dealership, and ask if that part number is for a hot cam, they should be happy to help
jeff
Old Jul 22, 2003 | 12:44 AM
86T/AWS6's Avatar
someone has to have a hot cam sittin around that isnt installed yet....this is really starting to bug me,,,i hope i didnt get ripped
Old Jul 22, 2003 | 06:18 AM
Mtrhds94Z's Avatar
186 98L
586 WB11
Are the #'s on mine..
I believe the 186 98L and WB11 are production run #'s, etc, and the 586 is the last 3 digits of the hotcam p/n[ as I previously stated]
I would say if it doesn't have '586' on the back end, stamped in, it isn't a hot cam.. the other #'s seem to vary.. and are rather random.. but the 586 is consistent..
Hope this helps..
Old Jul 22, 2003 | 12:32 PM
86T/AWS6's Avatar
see this cam doesnt have any other numbers stamped on the bacside, it only has the "110 97L"....could somebody else confirm that it needs the 586 to be a HOT cam....maybe Injuneer (Fred) knows somthin about this or how i could find out.....if i have to drive 3 hours to take this cam back im gonna be upset...
Old Jul 22, 2003 | 12:46 PM
ok i posted my #'s off my cam and Mtrhds94Z posted his, both have 586 at the begining of the bottom set of #'s. You seem to be only reading the top set because you keep giving a 6 diget code
