how could i tell if this cam is a LT4 hot cam??
I recently bought a cam from another board member...i had teh part number ready but there isnt a part number stamped on the cam...He also threw the box away to the cam....There are numbers stamped on the end of the cam, could someone with a hot cam out of their car please look at the end of theirs and tell what the numbers are stamped on yours??? i just wanna make sure i got what i payed for...thanks guys!!!
well whats stamped on your cam? i dont have a hotcam but the numbers might tell somethin.
342 99R
586 FM49 with a green dot |
Originally posted by faded93bird 342 99R 586 FM49 with a green dot |
my cam has "110 97L" stamped on teh end of it....please dont tell me i got ripped
i don't know, but wanted to add that i had a CompCams 270h in a 85' 350 SB, and it had 270h stamped on the end of it, so maybe this could help, but i doubt CC makes one w/ that #.
someone please help me here...im getting nervous....
there are two sets of numbers on my cam. I beleive that the top/or 6 digit number is a lot/ or product # the lower 7 digit code is the cam id #
if you have a micrometer, you can check the lobes of the cam
the only thing is a micrometer wont tell me the duration, or LSA....lift is lift....alto of cams have the same lift as teh HOT cam...does an LS1 cam look alot different? I found in pace performace a LS1 ASA cam that ends in teh parts number "110"...does an LS1 cam have the mechanical fuel pump lobe and a gear for a distributer???
call your local chev dealership, and ask if that part number is for a hot cam, they should be happy to help
jeff |
someone has to have a hot cam sittin around that isnt installed yet....this is really starting to bug me,,,i hope i didnt get ripped
Originally posted by 86T/AWS6 someone has to have a hot cam sittin around that isnt installed yet....this is really starting to bug me,,,i hope i didnt get ripped 186 98L 586 WB11 Are the #'s on mine.. I believe the 186 98L and WB11 are production run #'s, etc, and the 586 is the last 3 digits of the hotcam p/n[ as I previously stated] I would say if it doesn't have '586' on the back end, stamped in, it isn't a hot cam.. the other #'s seem to vary.. and are rather random.. but the 586 is consistent.. Hope this helps.. |
see this cam doesnt have any other numbers stamped on the bacside, it only has the "110 97L"....could somebody else confirm that it needs the 586 to be a HOT cam....maybe Injuneer (Fred) knows somthin about this or how i could find out.....if i have to drive 3 hours to take this cam back im gonna be upset...
ok i posted my #'s off my cam and Mtrhds94Z posted his, both have 586 at the begining of the bottom set of #'s. You seem to be only reading the top set because you keep giving a 6 diget code
