T56 removal, installation (with new clutch)
Old Jul 21, 2003 | 10:41 AM
NVetro's Avatar
I need to remove my t56 to install a clutch that is being fixed. Does anyone have a how to? Or can make one for me Any advice would also help, thanks all.
Old Jul 21, 2003 | 11:01 AM
Have you checked the "how to" databases at
Brent Franker's website
and at
Project TransAM?
Or "Install University" or whatever it is called?
Old Jul 21, 2003 | 11:24 AM
NVetro's Avatar
yea those are clutch install guides though, still usfull though.
Old Jul 21, 2003 | 11:32 AM
PatriotTA's Avatar
Do a search. I found 2 decent writeups by doing a search on this topic. I don't have them saved or else I would post them now. I just printed them off and then threw them away. I have had my T56 out twice now and it is really pretty easy. Here's an abridged version:
Remove your center console and shifter. Jack up the car and support it on jackstands at the four corners. Support the diff and the oil pan with jacks (use wood between jack and car). Drop the tunnel brace, then drop the driveshaft and torque arm. Undo the 2 nuts holding in the slave cylinder, remove that as well as its housing and hang the slave cylinder out of the way. Then pull the clutch fork down to disengage it. There are 8 (I thinK) 15mm bolts holding the trans to the bellhousing. Remove the 7 you can get to (you'll next swivels and extensions) and then undo the nut in the center of the tranny crossmember and then loosen (but don't remove!) the 4 bolts holding in the crossmember. This lets the trans sag so you can reach that dastardly top bolt from inside the car. Snake about 2.5 feet of extensions through the shifter hole to get that bugger out. Jack up the trans (again w/ wood) then remove the crossmember and the bolts. With the trans supported, stick a screwdriver in between the bellhousing and trans and pry the trans away. A second person come in handy here. Once the trans is far enough away, you can drop it down. Installation is the reverse, pretty easy once you've done it once. HTH
Old Jul 21, 2003 | 12:31 PM
Red96Lt1's Avatar
I bought one of those $15 Haynes manuals at autozone. I would say with avearage mechanical skills you would be able to do it yourself.
Old Jul 21, 2003 | 02:06 PM
importeater's Avatar
Well when you figure it out, you can come do mine!!
Old Jul 21, 2003 | 02:19 PM
tanker's Avatar
pull the fork out before pulling the tranny out, for everything else you don't even need a manual. write me if you encounter any questions
Old Jul 21, 2003 | 04:49 PM
Red96Lt1's Avatar
Yeah, forgot about that. It took me all day before I realized that!!!
Old Jul 21, 2003 | 08:25 PM
NVetro's Avatar
i keep hearing this torque arm thing, what is this? and will i have to remove it to drop the trans?
Old Jul 21, 2003 | 08:28 PM
PatriotTA's Avatar
Its that long black stamped steel "thing" that runs parallel to your driveshaft and connects the tailshaft of the tranny (via a rubber mount) to the diff. Its like a single, mid-mounted ladder bar. Yes, you have to drop it, along with the driveshaft (see my above post). Its simple. There is one 15mm bolt holding the mount together near the reverse-lockout solenoid on the tail-end of the tranny. There are 2 21mm nuts on 2 long bolts holding it in the diff. Its super easy to get out, but to get it in you need to play with the jack that's under the diff a little bit. Still an easy task though.
Old Jul 21, 2003 | 08:33 PM
gb95zconv's Avatar
Thats the long metal beam that connects the tranny to the rear differential. Remove it and the driveshaft first.
Old Jul 21, 2003 | 09:21 PM
NVetro's Avatar
Anyone in the northern NJ area want to help me out this weekend I a town over from the george washington bridge just to give u an idea. Anyone :-)
Old Jul 22, 2003 | 01:58 AM
Red96Lt1's Avatar
Don't worry so much about it. Once you get under the car it will be more straight forward.
Old Jul 22, 2003 | 07:25 AM
NVetro's Avatar
Lets hope, should i buy a tranny jack or should I i just hold the tranny on a jack with a peice of wood?
Old Jul 22, 2003 | 08:15 AM
NVetro's Avatar
Question, do i need air tools to get the flywheel bolts off? I dont have air tools, hehe.
