hotcam people in here (shift point for hotcam?)
Old Jul 19, 2003 | 08:58 PM
Fbody1's Avatar
can't find any thing in the search about the power band of the hot cam , or what rpm it should make peak hp,tq or best shift point. I know heads , exaust, flow will play a factor in it, can anyone help?
Old Jul 19, 2003 | 10:30 PM
Camaro_Maniac63's Avatar
GM says the HotCam works the best between 3000-6500rpm. I have the hotcam, and I would say that is true. My car doesn't have a lot going under 2500 rpm, but after 2500rpm, better hold on. I would recommend shifting at about 6000-6100 rpm.
Old Jul 19, 2003 | 10:56 PM
Sparkz28's Avatar
I shift mine at 6,500
Old Jul 20, 2003 | 07:19 AM
Smokn '94 Z's Avatar
Lightbulb
I had mine shifting at 6000 rpm but didn't like it. Now I have it at 6400 rpms. Don't know if it helped at the track but I like it.....
Old Jul 20, 2003 | 08:25 AM
FastZinTennessee's Avatar
Mine's set at 6200.
Old Jul 20, 2003 | 09:19 AM
TCAL95Z's Avatar
mines at 6500. Ed wright told me this too.
I have stock heads and a A4 with a vigilante and mine put down
329rwhp. I agree, below 2500 if you don't have a stall or the right gears it's lacking. When I had 4.10's and no vigilante the car ran even better.
Old Jul 20, 2003 | 09:57 AM
Kory 88 Iroc Lt-1's Avatar
Mine made max power at 6200. It dropped off by 1hp at 6400
Kory
Old Jul 20, 2003 | 10:59 AM
flyinZ's Avatar
not to steal this thread, but what about the CC-306??? with P/P heads, 2.00/1.56 valves???
Old Jul 20, 2003 | 02:28 PM
I think you should shift at 7500rpm, and if anything happens (how likely is that.....), you should sell me those heads and the cam for really cheap.
Old Jul 20, 2003 | 02:33 PM
flyinZ's Avatar
I don't think I can do that.....
I have my shift point set at 6200rpm, and 2-3 set at 6400rpm..is that too high??
Old Jul 20, 2003 | 02:39 PM
With that cam and the heads, I would say that is about right. You don't want to push our good old 2-bolt main blocks too much.
DirtyDaveW
Dec 1, 2016 05:37 PM
HarleyZ28
Oct 5, 2015 06:23 AM
k1996z28
Apr 13, 2015 06:54 PM
Z28Wilson
Aug 1, 2002 04:27 PM
