Skip Shift in 6 Speeds
Old Jul 18, 2003 | 04:46 PM
camarokid2003's Avatar
I know that GM put the SKip shifts in the 94 LT1 6 Speeds but did they put it in any other years. If so which ones and how do you get it off?
Old Jul 18, 2003 | 04:55 PM
jasons93z's Avatar
it was put in 94-2002. you can get it off by going to radio shack and buying a resistor and place it in the plug. Im not exactly sure on which resistor, maybe someone will chime in and tell.
Old Jul 18, 2003 | 05:08 PM
So the put them into 97 Formula firebirds. How hard is it to put the thing to stop the shift skip and how much.
Old Jul 18, 2003 | 05:51 PM
RobK's Avatar
You can also buy a pre-made part from various vendors for less than $15 last I checked. It's about the easiest mod you will ever do and never look back
Old Jul 18, 2003 | 08:43 PM
drewstealth's Avatar
Yeah its a very easy fix. I bought mine from summit. Pretty cheap. The skip shift light is still there but i don't even notice it anymore.
Old Jul 18, 2003 | 11:06 PM
You pull the harness plug off the skip shift solenoid, and insert a 2.2Kohm, 1/2 watt resistor in the harness plug, tape it up. Finished.
Driver's side of T56
F'n1996Z28SS
Aug 23, 2023 11:19 PM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
SLIMJIM
Jan 7, 2003 11:06 AM
Mykdiver
Aug 13, 2002 05:38 AM
