Tie-Rod
Old Jul 18, 2003 | 04:35 PM
Laymaster's Avatar
Tie-Rod
I have to replace a tie rod in my car...drivers side if it makes any difference.
Anything I should know like..I should get a certain name brand part or whatnot? Thanks in advance.
Old Jul 18, 2003 | 05:45 PM
revtime's Avatar
I like Moog, not too hard just make sure you loosen the adjuster bolt before you hammer out the old end.
Count the number of turns it takes to get the old on off and put the new one on the same number of turns. That will keep you close on the alignment.
Old Jul 18, 2003 | 06:56 PM
Laymaster's Avatar
Where do you pick up a tie-rod aside from Pep Boys. You mentioned Moog, should I order that from the web?
Old Jul 18, 2003 | 07:34 PM
93ZM6Tally's Avatar
Got mine from Discount Auto Parts. I used a piece of tape on the threaded end so when I screwed it back on it was the same length. They have a couple of different versions
Old Jul 19, 2003 | 02:53 AM
revtime's Avatar
I get my Moog stuff from NAPA.
Don,t know if you got one of those in Jersey.
Jesup16
May 20, 2013 01:38 PM
6SpdLT1Z
Nov 7, 2012 04:56 PM
Wischman
Aug 21, 2012 09:35 PM
ZZtop
Aug 17, 2012 01:07 PM
JeffsWorld
New England Area
11
Apr 3, 2007 12:00 PM
