Anybody here swapped a '98 instrument cluster into a '99 up ?
And, if so , did it change the temp readings ?
Also, who did the odometer reset & how many $'s for it ??
Thanks !!
Britt
'99 T/A
Best 13.071 @ 104.92
Now own '99 SS # 2073 !
12.969 @ 105.44
Thanks !!
Britt
'99 T/A
12.969 @ 105.44
A 98 cluster will not work in a 99+ nor will a 99+ cluster work in a 98. The pin-outs in the back are totally different for the 98's. All the rest of the years (99-up) are interchangeable.
Robert
1998 Camaro Z-28 M6
MODIFICATIONS
Engine: GMS Lid, FTRA, TByrne Red MAF Ends, BBK 80mm TB, 160* Thermo, 1 piece TB Bypass, SLP Fan Control Switch w/LED's
Drivetrain: SLP Short Throw Shifter, Lou's Short Stick w/ROBMOD, !CAGS
Suspension: BMR Dbl. Adjustable PHB, BMR LCA, BMR STB, KVR Cross Drilled (F/R)
Appearance: SLP Bowtie Grille, Clear Corners, T/A Power Antenna, Tinted Windows, Zaino
13.24 @107.75 w/2.17 60'
311rwhp / 328rwtq Dyno Graph
Pictures
Robert
1998 Camaro Z-28 M6
MODIFICATIONS
Pictures
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
