test?
Old Jul 18, 2003 | 01:21 PM
Bobbys_97_Z28's Avatar
test?
is there a way i could test the eec purge sol. to see if thats why im getting my p1441 code? or is it just a replace it and see thing??
the reason im asking is cuz im getting a hesitation from stop to go...only when the car is warm at reg temp......when cold it has more *****...
Old Jul 18, 2003 | 01:24 PM
On the EEC purge solenoid, pull off the vacuum line that goes from the purge solenoid to the throttle body. First make sure that there are no leaks in the vacuum line. Then plug the vacuum line up. Clear your code. Then take it for a drive. See if the hestitation disappears.
If the SES light comes on, check the code again. It will probably be the one for "no flow during purge" rather than the one for "flow during non-purge".
That will tell you if your P1441 has anything to do with the hesitation.
Old Jul 18, 2003 | 01:32 PM
sweet
sweet! thanx man...your my hero now....if i could only get outta work early to see that would be better thanx though!
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
Aaront810
Aug 29, 2020 09:34 PM
greenzee28
Sep 25, 2015 04:29 PM
jackpawt883
Sep 10, 2015 08:53 PM
