OBD1 PCM on OBD2 z28
Old Jul 18, 2003 | 11:14 AM
pillagenburn's Avatar
What would I need for this? Will it just plug straight in (the OBD1 PCM)? Or Should i just get a OBD2 PCM and get a OBD1 conversion done?
Just seems like OBD1 LT1 cars have many more tuning options....
and what about cost?
thanks!
Old Jul 18, 2003 | 11:19 AM
Camaro_Maniac63's Avatar
To do this conversion, you need to get a OBD-I PCM from a 94-95 GM car (preferably a z28), and you also need to get a 94-95 style knock sensor. If you can find an OBD-I from a 94-95 z28 in a junk yard, and also get the knock sensor, you are all set. Without the knock sensor, the car runs like crap. With the OBD-I, tuning is easier and most importantly, cheaper. Good luck.
Old Jul 18, 2003 | 11:22 AM
Where does the knock sensor connect on LT1's ?
thanks
Old Jul 18, 2003 | 11:25 AM
turbo_Z's Avatar
thanks
its on the pass. side of the motor below the head.. i believe right beside the oil dipstick where it goes into the block.
Old Jul 18, 2003 | 03:38 PM
do you have to drain the coolant or anything before you swap the knock sensor?
Old Jul 18, 2003 | 03:52 PM
You will drain coolant when you pull the knock sensor, since it take the place of the block coolant drain plug for the passenger side.
Old Jul 18, 2003 | 03:58 PM
jeremyferguson's Avatar
Are the only advantages of obd-II emission controls, what would be a good reason not to do it. I have been thinking about this....
Old Jul 18, 2003 | 04:01 PM
Rodrigues's Avatar
Would the 1995 OBD II style connector work with a 1996 converted to OBD I ALDL connector?
Old Jul 18, 2003 | 05:26 PM
sleeperZ96BT's Avatar
PCMforless has a complete conversion for OBD2 cars............plus unlimited updates...........thats what I did.
Brian
Old Jul 19, 2003 | 08:53 AM
steve40's Avatar
yeah, you can go to pcmforless or madz28 and get a conversion pcm and just plug it in without having to change the knock sensor
HectorM52
Jul 30, 2017 11:46 AM
Deadbolt24
Jan 19, 2015 01:29 PM
Jan 5, 2015 07:14 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
thenewkid
Nov 27, 2014 09:41 AM
