coolant gone, dunno where it go
Old Jul 18, 2003 | 10:30 AM
TMD95Z28's Avatar
i have a problem.. last week i'd just finished draining my coolant from the radiator, and i fill it up back with water. now the problem is every morning my coolant level was low in the radiator, theres no leak underneath the car, the oil seems fine (not milky).
but i just don't get it, wheres all the coolant go??
btw how many gallons of coolant+water can a camaro z28 take??
any info will be so much appreciated
Old Jul 18, 2003 | 06:24 PM
scoobysnax83's Avatar
I'd say first off the best bet would be to replace the radiator cap. If this is going then you could be overflowing into the overflow container, and leaking out the top. Do you smell coolant at all?
Old Jul 18, 2003 | 09:31 PM
gb95zconv's Avatar
You could have had some air pockets in the system.....fill it ,bleed it and keep checking it.
Old Jul 18, 2003 | 09:36 PM
Good call.....
Old Jul 18, 2003 | 10:07 PM
TMDZ28's Avatar
Originally posted by scoobysnax83
Good call.....
we did that already, about 4 times.
Old Jul 18, 2003 | 11:53 PM
TMD95Z28's Avatar
no coolant smell at all..and i'd already bleed it lots of times..
still gone
Old Jul 19, 2003 | 05:26 PM
Z95m6's Avatar
my radiator had a hole in it and it would only leak when the car was running. It was a very small hole and even if the coolant was above the hole it wouldn't leak. The only way i noticed it was i fired up the car and watched it start peeing a stream out the hole.
Old Jul 19, 2003 | 07:46 PM
D James's Avatar
I would check and double check the engine to make sure there is no sign of coolant leaking, its got to be going somewhere. The other guys gave good clues, hopefully its not like the car I'm fixing right now the engine was sucking coolant but no smell, no sign of it in the oil, then one day, boom headgasket blown, now I know it was going into the engine. Usually there is even signs of white in the combustion chamber, but I didn't have that either. when my waterpump went, it was mysteriously sucking coolant, well after a close examination I noticed the weephole on the pump was dripping coolant, just enough where it stayed on the engine but never leaked on the ground.
Old Jul 19, 2003 | 08:01 PM
Joe Bellman's Avatar
Good idea here.
Is the car smoking at all? Or does the exhuast smell different?
Check the tranny, maybe the tranny cooler is letting coolant from the radiator into it. Mine did that once but the other way around. My anti-freeze was red on top from ATF getting in the radiator.
Old Jul 19, 2003 | 10:36 PM
Rocksteady's Avatar
Rad Leak
I just went thru this. The Rad has plastic end's. I had a pin hole leak. It took me a month to find it. If your not see it the oil that's prob the problem. Let the engine run till it get's to normal operating temp. Shut it off and look for steam. Make sure you check under the car also. If you have to replace the plastic end most Rad shops will do it for 90.00 a side.
Old Jul 19, 2003 | 11:11 PM
rage366's Avatar
i'm replacing mine on monday...it has a small leak, and since the water's under pressure, it's not really water...when it escapes, it's gas, so, it's not really taking a leak.
i've had lots of heating problems, and in the end, the problem was simple...two hoses were switched...
Old Jul 20, 2003 | 09:16 PM
TMD95Z28's Avatar
i just checked to day and my coolant is still full.. i guess i didn't fill the radiator till its max.. so it need more coolant. but now its okay, run cool and smooth.. anyway thank for all the info, i'd appreciate it.
yeehaaa nothin goes wrong with my car...
and oh Rocksteady.. what is a plastic end???
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
