Shoebox my problem is solved, but.....
Old Jul 16, 2003 | 05:14 PM
dnz28's Avatar
I put in a new vats module the car will run now thanks alot but now A nother problem accured My radio will not turn on and the courtesy lights stay on no matter what and the rear the electric hatch release to the back also doesn't operate correctly. All small problems that can be worked out I hope. Do you have any idea of what is causeing this. I really apperciate all the help you have giving me.
Old Jul 16, 2003 | 05:29 PM
dnz28's Avatar
I forgot to say the security light still is flashing to.Even when I am driving.
Old Jul 16, 2003 | 05:31 PM
KyleMailman's Avatar
Mine does that also. Is there a way to fix it?
Old Jul 16, 2003 | 07:44 PM
dnz28's Avatar
Come on people I help you out now you help me.
Old Jul 16, 2003 | 08:43 PM
It is important to have the year model when looking up wiring diagrams.
If you put in a new module and have the security light flashing, your new module is not programmed and you have a problem with it not reading the key. (Maybe that was the original problem -I don't remember) When a new module is installed, it will read the key resistance and program itself to it. It will only do that once. The new module cannot program itself to the key if it cannot read it.
You need to make sure your key is ok. If it is, then you need to test the harness from the key cylinder to the connector at the bottom of the steering column (plug with wht/blk, ppl/wht wires in it). If it is bad, you can either replace it or bypass it with a resistor to match your key pellet resistance. Your key cylinder may just be dirty, too.
Old Jul 16, 2003 | 08:52 PM
dnz28's Avatar
I got everything else to work but the light is still flashing would it hurt if I just let it keep flashing.
Old Jul 16, 2003 | 11:03 PM
No, it won't hurt, except the PassKey system is not functional and your car will be easier to steal.
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
derty
Sep 5, 2002 05:01 PM
SAR2K
Sep 1, 2002 10:49 AM
Zone
Aug 2, 2002 04:36 PM
