Took car to the track....idles rough now
Old Aug 4, 2002 | 01:00 AM
Pentatonic's Avatar
Angry Took car to the track....idles rough now
...well, it doesn't idle rough persae, but definately not as smooth as it used to. Before I took my car to the track last week, the car idled incredibly smooth. When my car was at a stop-light, if the radio was on, you wouldn't even know the engine was running, no vibrations or anything. But now, at idle, I am getting these intermitent vibrations in the car, accompanied by a small drop in RPM's, like from 550 to 500 or 450.
Should I be worried or are these idle vibrations normal? Did I put a little too much wear and tear on some of the engine components? The car has 23,000 miles and still has factory spark plugs, and is completely stock.
Dennis
2000 Camaro SS
black, A4, tinted windows, stock for now
[This message has been edited by Pentatonic (edited August 04, 2002).]
Old Aug 4, 2002 | 01:52 AM
99Z28RS's Avatar
Post
I posted a question just like this a while back because my car was doing the EXACT same thing you just described one day, but hasn't done it since, i have the mods (in Sig) and a few people responded with Little confidence in what the problem was but someone suggested that it was bad gas, or Possible a vacuum leak, but I think Ill just go with the bad gas theory!
99 Z28RS
SLP LoudMouth
SLP Air Temp Module
MTI Carbon Fiber Air Lid/K&N
EGR Mod,FRA Mod
Old Aug 4, 2002 | 12:10 PM
Pentatonic's Avatar
Post
Hmmm....well, perhaps my fuel filter may have gotten a little clogged? Unfortunately, my problem has not gone away yet.
Dennis
2000 Camaro SS
Old Aug 4, 2002 | 05:13 PM
romanss's Avatar
From: windsor,ontario,canada Home of the fastest LS1 and LT1 6-speeds :D
Post
A couple of times after I went racing the car ran a bit rough and dropped to a lower idle. After a little bit of running the car around "normal" the problem would go away. I wrote it off as a computer re-teach, that after some serious thrashing the computer needed some time to re-gain consciousness.
Good luck.
p.s. quick question, did you try race fuel? I've also had the o2's go a bit wacky after that.
Old Aug 4, 2002 | 05:34 PM
Pentatonic's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by romanss:
I wrote it off as a computer re-teach....</font>
uuuuh....Computer re-teach? Hmmm...I guess my carburated mind doesn't think in terms of the computer.
<font face="Verdana, Arial" size="2">p.s. quick question, did you try race fuel? I've also had the o2's go a bit wacky after that.</font>
No, no racing fuel. Just 93 octane pump gas.
bfmv13trivium
Jan 14, 2015 09:57 AM
cmdeshon
Dec 12, 2014 10:51 PM
ModdedNerd
Dec 10, 2014 08:42 PM
NewsBot
Dec 3, 2014 12:30 PM
USAirman93
Nov 24, 2014 03:37 PM
