At what temp. does OBDII enter into closed loop
Old Jul 14, 2003 | 04:03 PM
jchevy's Avatar
Trying to figure out if i want to run a 160 t-stat or not. What temperature does the PCM enter closed loop on a 97. Is there any other factors that effect whether or not it goes into closed loop.
Old Jul 14, 2003 | 04:05 PM
Coolant temp for closed loop varies, over the range of 120-140degF. You will not have a problem with a 160degF 'stat.
The two other things that enable closed loop are hot/active O2 sensors, and a timer that seems to be about 2 minutes after startup in summer weather.
Old Jul 14, 2003 | 04:12 PM
jchevy's Avatar
Thanks.
I had a 160 in my 95 Z28 and the car liked it, i put one in my 96 and it didnt seem to run as good. I was wondering if it had something to do with OBD2 compueter.
Maybe it was just me.
I guess ill try it in the 97.
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Sep 18, 2015 03:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
