Bad MAP Sensor?? Help!
Old Jul 9, 2003 | 09:34 PM
RRios8191's Avatar
Exclamation Bad MAP Sensor?? Help!
Can you clean it?
I pulled mine out and it was filthy. Car has been running like crap lately!!
I pulled sensor out while car running and car shut off.
Is it supposed to do that??
Old Jul 9, 2003 | 10:16 PM
Re: Bad MAP Sensor?? Help!
Originally posted by RRios8191
Can you clean it?
You could possilbly clean it. Be gentle. I would imagine it would be hard for the computer to manage sensing the load on the engine with the sensor removed, not to mention the vacuum leak from pulling it out.
There is a little accordian-like seal with it. Is that intact?
Old Jul 9, 2003 | 10:20 PM
RRios8191's Avatar
Accordion Seal
It was intact but all bunched up on one side.
I'm going to pull it back out and clean it with soap and water??
Does that stem valve on teh sensor itself serve any purpose ?? I tried forcing air inside it and no go. Seemed blocked off, or should it be that way??
Old Jul 9, 2003 | 10:32 PM
Basically, it is a vacuum sensor. There is probably a diaphragm or something inside it, so don't poke way inside too much.
Stem valve? Do you mean the part the goes into the manifold?
Old Jul 9, 2003 | 10:34 PM
RRios8191's Avatar
Yes
Part that goes into manifold yes.
How much is a new one?
Old Jul 9, 2003 | 10:48 PM
Re: Yes
The part that goes into the manifold is where it picks up the vacuum. The sensor would be a sealed unit except for the hole in that part of it.
1993-1997 MAP sensor
ACDelco #213-185
GM p/n 12569240
$35-$40-ish
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
99TransAmWS6
Mar 22, 2015 11:00 PM
Fatdog2
Feb 13, 2015 08:19 PM
Amshnock
14
Jan 18, 2015 11:47 AM
