what do you think of the mcleod clutches?
Old Jul 12, 2002 | 07:22 PM
phil1001's Avatar
Post what do you think of the mcleod clutches?
my centerforce dual friction is ok, but not enough clutch for the 5k dumps, anyone use the mcleod clutch? hows it work? any troubles?
2000 black WS6 6speed
318 RWHP 322 RWTQ stock
best et: 12.72 with the et streets. 60' 1.81
bestmph: 109.72 first time out, no mods, on the street tires
Mods: centerforce dual friction clutch, moser 12 bolt w/4.10's
BFG dragradials, PRO 5.0 shifter
whats next: put the borla on, take baffles out of WS6 hood, tb bypass, et streets
Old Jul 12, 2002 | 11:42 PM
derty's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by phil1001:
</font>
So far I like my McLeod single disk quite a bit. Gave it a 4800 dump today and it was fine. No real trouble with the clutch, but I would recommend a new slave when you change yours over. Thought my old slave would have been good enough off the stock clutch. It gave out right away and started leaking fluid. That sucked... anyway that's my $.02.
Grand Rapids, MI
2002 WS6
http://www.sigma-epsilon.org/steve
stevedertien@attbi.com
Whisper Lid, Grotyohann Headers and Y-pipe, Corsa Exhaust, BMR SFC's, McLeod Single Disk, Spohn Torque Arm, LCA and Panhard Rod and much more to come
Old Jul 12, 2002 | 11:58 PM
rncotton's Avatar
Post
You might want to read THIS first.
2001 TransAm WS6, M6 3.42
HPP, TBB, 160* t-stat, MTI Lid, Holley PowerShot, Flowmaster 80, Port/Polish MAF
2001 Z28
-- R.I.P. - 06/25/02
Old Jul 14, 2002 | 05:43 PM
phil1001's Avatar
Post
ttt
Old Jul 15, 2002 | 11:33 AM
onebad97z's Avatar
Post
my friend has one in his 96 ws6 and i only have two words to say about it.
BAD ***!
he dumped it about 5500 or so and it holds up awsome.
Old Jul 17, 2002 | 10:05 PM
ScLeCo's Avatar
Post
I personally like my SPEC stage 3, its been able to handle 425 RWHP 400 RWT, and 4,500RPM dumps with out any problems, and it was only $500.00
//BLACK 99 SS//M-6//T-Top//TR 224/224 .561/.561 112LSA//CNC Stage 2 Heads 2.08"Intake-1.60" Exhaust Valves//Volant Cold Air Induction//BBK 80mm Throttle Body//SLP Stage 1 Suspension Kit// Powerslut Rotors//Hawk Pads//Mosser 12 bolt-4.10 Gears//SPEC Stage 3 Clutch//ASP Underdrive Pulley//Lingenfelter Aluminum Driveshaft//BMR Sway Bars-Lower Controll Arms-Panhard Rod-Track Pak-Strut Tower Brace//Taylor Wires-NGK plugs//HPP 3-160 Stat//Skip Shift Eliminator//B&M Ripper Shifter//SLP LT Headers-SLP ORY No Cats//Borla Cat Back//Dynomax Bullit//ECT...
Old Jul 18, 2002 | 10:05 AM
BlackBowTie's Avatar
Question
When you are talking about "DUMPS" what do you mean? I.E. 5000 Dump?
"Mustang Killer"
Black 2002 Z28 M6 T tops
SLP LID
SLP BELLOW
K&N Fillter
Old Jul 18, 2002 | 11:14 AM
rncotton's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by BlackBowTie:
</font>
How fast can you get your foot off the clutch? Just yank your foot away and let the clutch pedal spring back up into place ... that's a dump.
Personally, dumping over 3,500 RPM will smoke the tires in my ride. I guess I need stickier tires than these Michellin POS tires that the dealer installed.
2001 Z28
Old Jul 18, 2002 | 06:41 PM
ScLeCo's Avatar
Cool
I can smoke my rears at about 2,500 RPM dump, but that was what I was after those cool very expensive smoky burnouts
Old Jul 18, 2002 | 11:27 PM
goaliedave40's Avatar
Thumbs up
Great info, sorry it cost so much on your end, though.
<font face="Verdana, Arial" size="2">Originally posted by rncotton:
</font>
1999 Z-28 M6: Gran.MAF, LS1 MoSports intake, K+N filter,Corsa exhaust, PowerSlot rotors, Hoch. strut tower bar, still working
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
