Sawtooth dyno graph
Old Jul 1, 2003 | 07:21 AM
Grover's Avatar
Sawtooth dyno graph
I finally got the text file from my dyno tuner with all the data in it for my dyno tune and put it into Excel. When I graph the HP & TQ it is very choppy. The Excel file can be found Here
What would cause a graph to look like this?
Here is the original thread about it. The numbers after the dyno tune were 349.3HP @ 6000 & 323.8 TQ @ 5250 on a Mustang Dyno.
Old Jul 1, 2003 | 07:27 AM
GhostZ's Avatar
My first dyno was choppy as well....much worse than yours actually...that was traced to an ignition problem.
Do you still have the dyno graph? The link on the other thread is broken.
Old Jul 1, 2003 | 07:54 AM
Grover's Avatar
That's an interesting thought about an ignition problem. I am running a MSD Digital 6+ for use with the NX wet kit. I am changing the spark plugs right now, so I will see how they look.
I didn't have the original scan of the dyno graph, so I took a picture of it with my digital camera and the link in the other thread now works.
Old Jul 1, 2003 | 10:12 AM
LPEdave's Avatar
I was going to say knock retard, until I saw the graph. I agree with the ignition suggestion... including the opti...
Dave
Old Jul 1, 2003 | 10:21 AM
Grover's Avatar
I just got done changing the spark plugs from TR55 to TR6 and 1-5 looked pretty clean, but 6-8 were pretty brown and the tip that the plug wire presses onto wasn't screwed down tight. Do you think that could have an effect?
I can post a picture of the plugs if you want to see them.
Thanks.
Old Jul 1, 2003 | 10:38 AM
Zeueses 97 RamAir's Avatar
torque
Your torque is a little low I have hooker lt with holley tb dynoed at 312 341 torque check the tuning or try some pullies
fift5
11
Oct 1, 2015 10:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
Strick
Jul 14, 2015 07:28 AM
