18" C5 rims on a SS??
Old Jun 27, 2002 | 01:54 PM
nuclearfly's Avatar
Question 18" C5 rims on a SS??
I was wondering how much modifying I would have to do to my SS in order to squeeze the 18" Silver C5 rims under the car. I was hoping to get 18s on all four corners, instead of just the back, without tubbing anything out. Any info is appreciated, including tire size needed. Even if the overall tire hieght was the same as my 17"s with 275/40s on it would be fine.
[This message has been edited by nuclearfly (edited June 27, 2002).]
Old Jun 27, 2002 | 02:36 PM
noe95z28's Avatar
Post
I have the y2k vette rims w/ 285/35/18z all the way around w/no rubbing or any problems; Just make sure to get it re-aligned
Old Jun 27, 2002 | 04:02 PM
WhiteDeathLS1's Avatar
Lightbulb
Some people have had to use spacers and have encountered rubbing issues do to these reasons:
(1)They obtained a wheel with the wrong offset. Performance Wheel Outlet sells the 18" Vette wheel with the correct offset for an f-body (I think it is 50mm) Other wise you may have to use spacers to make the wheels fit correctly.
(2)The wrong tire combo was used. If you want to match the exact stock diameter of your car so that your speedo doesn't go coo-coo, then you will have to go with a 275/35/18 tire.
Good luck with these awesome wheels
http://camaroz28.cardomain.com/id/whitedeathls1
1999 Sebring Silver Metallic Z28, M6 T-tops
Cosmetic Mods: GM SS Hood, 18" Y2K Chrome Corvette rims on Kumho Ecsta 712s in 275/35/18ZR, Corvette FRL covers (More to come!...)
HP Mods: Borla Catback, Granatelli MAF, Whisper lid with K&N, Free Ram Air, Superior 4.10s w/Ratech Crush Collar Kit, TA girdle w/stud kit, HPP3 w/160 t-stat, MMS ported TB, EGR and TB coolant bypass, ASP crank & Alternator pulleys
Suspension Mods: KBDD SFCs, Spohn LCAs & Adjustable PHR, Addco 32MM front and 1LE rear sway bars, BMR STB, Eibach Pro-kit
Extras: B&M Ripper shifter with RK Sport Satin Finish shift ****, Mobil 1 filler cap.
320rwp, 325 max torque on MMS Dyno jet!
R.I.P. 1998 Z28, 1/23/2002
Old Jun 28, 2002 | 04:59 PM
nuclearfly's Avatar
Post
Since the C5 wheels are 9.5" wide, shouldn't I need a wider tire, like 295s maybe??
Old Jun 30, 2002 | 11:24 AM
acarnut's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by nuclearfly:
Since the C5 wheels are 9.5" wide, shouldn't I need a wider tire, like 295s maybe??</font>
275/35 is a good match to a 9.5" rim (11" would be the max for this tire). The taller and wider 295's will be a problem on the front, and a tight fit on a 9.5" rim.
275/35's, on the right wheel, shouldn't require any mods to the car like rolling the rear fender lip.
http://member.newsguy.com/~acarnut/
http://www.geocities.com/motorcity/1701/pwosucks.htm
DaveH
Old Jul 1, 2002 | 01:59 PM
nuclearfly's Avatar
Post
Thanks for the input guys. Hopefully I'll be geting these rims soon!
Old Jul 1, 2002 | 02:56 PM
ankle-biter's Avatar
Post
You're likely looking at lowering the SS too.
See Y2K before I lowered mines.
Bob
'02 Z/28 Silver 6spd, Magna Flow muffler, no catback, Whisper Lid, Y2K C5 Silver 17"/18"
305hp 320tq
Old Sep 2, 2003 | 12:46 PM
nuclearfly's Avatar
My SS is already lowered an inch.
Old Sep 2, 2003 | 01:16 PM
Lan01z's Avatar
The widest you can go on 9.5 is 285
Old Sep 2, 2003 | 03:10 PM
badeSSt's Avatar
man you can go ahead and do 18x9.5 and run a 285/35/18, my friend runs them on his ta and its lowered with the ss bistein springs. you may need to pound your inner rear fenderwells just a little.
Old Sep 2, 2003 | 04:55 PM
01SunsetOrangeSS's Avatar
WhiteDeathLS1 is exactly right. 275/35/18 is equal in circumference to a 275/40/17 and that is what I would use on my car. Just be forwarned that the extra unsprung weight will slow the car slightly.
Old Sep 2, 2003 | 07:11 PM
BlownLS1's Avatar
On my 00 SS, I put 18"*9.5 Z06 rims. They clear fine with 275/35/18, even with the 1.8' drop in the front and rear.
The C5 rims should look nice
Old Sep 3, 2003 | 01:55 PM
nuclearfly's Avatar
I appreciate the help guys. I still don't have the wheels, but once she's running right, we'll see how it goes.
Old Sep 3, 2003 | 04:49 PM
danziger's Avatar
Unhappy
I have 275/40s in back on 18 inch Vette rims. They rub and are too tall. The 275 or 285/35s sound like a better option. I am actually looking for a replacement set of 17 inch rims as I think the 18s are too heavy and don't give any performance advantage.
Old Sep 4, 2003 | 03:37 PM
nuclearfly's Avatar
Im not really looking for a performance advantage, Just styling, and I think 3 of my 4 rims are bent.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
Formula Steve
Sep 19, 2015 08:48 PM
rvonsternberg
Sep 14, 2015 11:58 AM
scottcba1
Sep 8, 2015 09:52 AM
