Clutch won't disengage?!?!
Old Jun 28, 2003 | 12:11 PM
notstock4long's Avatar
I put my new engine in, along with a new clutch, but it doesn' work right. It is really hard to get into gear, and if the clutch is in with the car in gear, it won't disengage. So if its in first and I try to start it, it just jumps forward.
Could this be because it is new, and the pressure plate and clutch are just stuck together a little? I have heard of some people just letting the car lurch forward until it frees itself. Would this work?
I just don't want to have to take the tranny off again.
Old Jun 28, 2003 | 12:15 PM
LT1ponykilla's Avatar
It could possibly be the master or slave cylinders.
Old Jun 28, 2003 | 01:18 PM
96 WS6's Avatar
The slave cylinder is probably not pushing the throwout bearing all the way in. You did not install something right and i'm sorry but you might have to take it out again...
Old Jun 28, 2003 | 03:59 PM
I am 99% sure the flywheel, clutch, and pp are in right. Maybe the stick on the slave cylinder is hitting the edge of the clutch fork or something because it isn't in right. Any other possibilities?
I am hoping something is just stuck and will come apart after starting the car.
Old Jun 28, 2003 | 06:15 PM
I think I might have found the solution. Is the rod coming out of the slave cylinder supposed to flop around? If it's not, then I think the rod is broke. Is it supposed to move freely, or come straight out of the cylinder?
Old Jun 29, 2003 | 09:07 AM
TTT
I still am not sure what is wrong. Sometimes it works and sometimes it doesn't. Is the slave cylinder pushrod supposed to come straight out, or should it move frelely in the end of the cylinder?
sherwinZ28
11
Aug 15, 2015 05:38 PM
Jlo
Jul 29, 2015 03:52 PM
ducttape1975
Jul 10, 2015 06:29 PM
mrwz28
Jul 8, 2015 09:11 PM
