Stage 1 and 2 heads......3?
Old Jun 25, 2003 | 02:40 PM
GoFast908Z's Avatar
Member
Question Stage 1 and 2 heads......3?
First, what are the differences between Stage 1 and Stage 2 heads for the LT1?
Second, are there such things as Stage 3 heads?
Old Jun 25, 2003 | 02:54 PM
94formulabz's Avatar
It's completely up to who makes them. I'm the only one who replyed to this thread, but here it is anyways:
http://web.camaross.com/forums/showt...hreadid=135344
Old Jun 25, 2003 | 03:00 PM
Chris 96 WS6's Avatar
THe GTP stage 1's I used to have had a gasket match and the intake and exhaust bowls were reworked for better flow. That, plus the typical machine work, was it.
THe typical stage 2 adds full porting to the runners plus usually some smoothing of the chambers.
Old Jun 25, 2003 | 03:10 PM
What chris said is typical of the increasing work put into the stage I vs II heads. The point i was trying to make was that there is no standard flow they have to meet so some stage IIs will be better than others. It's good for comparing heads from the same manufacturer, but between manufacturers you really need the flow numbers.
Old Jun 25, 2003 | 05:51 PM
GoFast908Z's Avatar
Member
So I take it, there is no Stage 3?
Also, I'm planning to run a ATI Procharger on a 96 LT1, which heads should I use. I want all bolt-ons and the SC, hopefully hit deep 10's
Old Jun 25, 2003 | 06:05 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
BAM!
Old Jun 26, 2003 | 01:44 AM
GoFast908Z's Avatar
Member
which heads could I use with the SC? I like the Stage 3, but won't more flow increase the compression?
95craz28
11
Sep 12, 2015 07:47 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
karpetcm
Aug 14, 2015 03:02 PM
Henson071
Aug 4, 2015 09:32 AM
Boss002
Jul 9, 2015 03:33 PM
