Autocross and Road Racing Technique There is more to life than a straight line
What Exactly Does The Panhard Bar Do?
Old Jun 24, 2003 | 06:40 AM
mc63's Avatar
Could someone explain what the panhard bar does ?
My 95 Z feels like the rearend is twisting as I let out on the clutch and take off. It "feels" more on the right rear, as if the suspension is giving and allowing the rearend to roll.
I have installed new Bilstein shocks and this did not make any difference.
Please Help Anyone,
Thank You,
Michael
Old Jun 24, 2003 | 08:03 AM
bruecksteve's Avatar
The panhard rod keeps your rearend centered on the car. The stock bar can have considerable flex (along with the bushings) and allow the axle to move from side to side. It's hard to tell if that's what your experiencing or not. I had one break on me before and it's not something you want to happen at speed!! If your car has been lowered it's possible that the axle is off center. Some people see more change than others and generally it's not alot but if you run 11" wide wheels it can become an issue.
I just noticed you're in Atlanta too!!
Old Jun 24, 2003 | 12:08 PM
mc63's Avatar
Thank's for the reply!!!
It's not side to side, it feels more like the rearend is twisting under torque.
Old Jun 24, 2003 | 12:10 PM
you mean like one side going up, one side going down???
Old Jun 24, 2003 | 01:57 PM
2002Z28SSConv's Avatar
The most likely point of failure is the lower control arm bushings. If that's not it try checking the bushing at the front of the torque arm by the tranny mount. Check that to btw. It could also be loose bolts where the toreque arm joins the rear end. It's rare on a car that isn't heavily modded but I've seen broken torque arms too. That's about the only parts that could let the rear end twist under load.
Old Jun 24, 2003 | 09:09 PM
mc63's Avatar
Thanks, I'll check it out
Old Jun 26, 2003 | 11:27 AM
Z28SORR's Avatar
I agree, With that many miles on the car, the LCA bushing are most likely bad. Good time to up grade to poly?
Old Jun 26, 2003 | 11:48 PM
black97z28LT1's Avatar
i noticed that you said it felt like your car was twistin to the right rear...well that is how it is on every rear wheel drive car....everycar goes back and to the right...that is why so people put just one airbag under the right rear to stop that twist...but it is nothing wrong with your panhard bar that is making your car do that
Old Jul 2, 2003 | 09:52 PM
cndctrdj's Avatar
ya at around 145 my car sways too everyone told me that it was my panhard rod / springs so try those to stop sway
Quickss96
Jan 29, 2016 05:56 PM
football4life
Oct 4, 2015 07:48 AM
Henson071
Sep 18, 2015 04:01 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
