On my way to true duals
Old Jun 23, 2003 | 11:54 PM
LS1-Maniac's Avatar
Cool On my way to true duals
I just ordered 2 Dynamax Magnum Race Bullet mufflers with 3" inlets and outlets which are due at my house in 2 days. As soon as I get my headers installed my shop is going to custom make my X-pipe and install it onto my headers with the bullets welded onto the end. I'm going to clamp on a 3" downpipe on the end of each bullet temporarily for the show this saturday and afterwards I may try out a side pipe set-up. Should I weld any pipes to my headers or should I strickly bolt-on to the headers?
Old Jun 24, 2003 | 12:16 AM
SpidermanForever's Avatar
Will that be dumped directly under the car? If so , it will be loud as hell and droney in the car. Won't be as bad if you run them all the way to the back.
Old Jun 24, 2003 | 01:10 AM
mr_muff's Avatar
that and you might need them to come out the back for emissions. i know you need them out the back where i live
Old Jun 24, 2003 | 05:56 AM
LS1-Maniac's Avatar
For right now I'm gonna dump them under the car. Later I'm going to run side-pipes if I can find a way around the ground clearance issues. I also changed the design some and I'm gonna try an H-Pipe instead of an X. Whole system will be 3 inch from the headers back.
There's no emissions testing in Kentucky so I don't have to worry about that.
Old Jun 24, 2003 | 03:25 PM
2000LS1Z28's Avatar
I'd stay with the X-pipe. Will make more power than the H set-up(especially in the low to mid range) and has a smoother more refined sound.
Mike
Old Jun 24, 2003 | 04:15 PM
Capn Pete's Avatar
Cool
This topic was discussed a few months ago, and I saved a site with some pics. Except for the ground clearance issues that apparently can be bad, I think it's a cool setup.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
