clutch installation 2001 M6 tips please
Old Jun 9, 2002 | 06:34 PM
madmanmike's Avatar
Post clutch installation 2001 M6 tips please
Hello, I'm about to install a Z06 clutch kit on my 2001 Camaro SS M6. My pal is a mechanic, sees no problem. My mission, to find out any tricks getting off the console, and any other tricks from the Z28.com crowd. I see the screws under the flip compartment, I'm all ears. Thank you
____________________________________
2001 SS Red Convert M6 Hrst. all SLP options with center exhaust, FIPK, 555R Nittos that ate the clutch mjwarner@charter.com
Old Jun 10, 2002 | 07:34 AM
TA2001's Avatar
Post
This will help you ..
http://www.ls1info.com/article.php?sid=14
Old Jun 10, 2002 | 07:06 PM
SS_HOTROD's Avatar
Cool
no special tricks, just torque, locktite, and install correctly. also bench or reverse bleed the slave and master cylinder. im using a spec stage III carbon and its awsome but i have exceeded its 500 hp limit.
-performance mods-ARE stageII heads and cam, FLP headers/off road y-pipe, mac catback, random technology torque arm, subframe connectors, pro 5.0 shifter,TA rear girdle, 3:73 gears, performance suspension, duel gauges, free mods,trailing arms and panhard rod,!CAGS
vortech 9lb/intercooled
Star stageIII/carbon, etc.
Old Jun 10, 2002 | 09:44 PM
madmanmike's Avatar
Talking
TA2001 & SS_HOTROD, thank you very much. I want to be real sure not to mess up any of the interior woodwork, I mean black plastic. I was tempted to go stronger on the clutch, but will install the Z06 and play. With the FIPK and Nittos, I'm not too far off stock. As a convertible, I want to stay slower than roll cage requirements. At least, that is what I am telling myself. (Bolt on supercharger sounds pretty outrageous)
BPS
9
Mar 5, 2015 10:51 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
mritter1965
Exhaust System
Feb 15, 2015 07:31 AM
HectorM52
Jan 30, 2015 11:08 PM
