high-temp copper gasket maker to seal AIR fitting?
Old Jun 22, 2003 | 05:47 PM
Stock Z's Avatar
So I am going to plug the AIR fitting using some plain bolts will high temp gasket maker work here? (oh btw this is on RK Sport headers)
Old Jun 22, 2003 | 06:21 PM
ChvyCruzen's Avatar
IM surprised that you found bolts that will plug your AIR for your exhaust. I couldnt find any. I took the valves, cut them off about 1.5 inches away from the nut and brazed it shut. Works real good. I dont think that high temp copper gasket would help at all. You need anti-seize and a solid bolt to plug it off.
Old Jun 22, 2003 | 06:43 PM
danner's Avatar
dont use anti seize, it will melt down and work its way down and toast your o2 sensors, aks me how i know
Old Jun 23, 2003 | 09:14 PM
arnie's Avatar
He didn't. That is why he is scrambling for sealer to patch the gaps. There are the correct thread pitch plugs available though. They are custom made.
There should not be any problem using anti sieze. It has a purpose, just not meant to seal, that's all.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
95chwagon
Jan 13, 2015 09:19 PM
Jazsun
Dec 29, 2014 12:14 PM
