Injuneer Fred!!!
Old Jun 22, 2003 | 04:46 PM
96 WS6's Avatar
Injuneer Fred!!!
How did you install your 5" tach on those ridges on the defroster hole? I don't want to drill into my dash or some ****. I was going to put it on the pillar but I don't know if that will be within my field of vision when I'm driving. I figured that you would have been able to install it without tearing up your dash since you are THE guru...
Old Jun 22, 2003 | 05:02 PM
Blue89Bird's Avatar
maybe some sort of bracing underneath. Thats what I would do anyway.
Old Jun 23, 2003 | 03:09 AM
96 WS6's Avatar
TTT
Old Jun 23, 2003 | 07:39 AM
Toggle bolts. It may shake a little, depending where you locate the tach. The alternative is to drill the screws into the ductwork under the vent grid. I also put a piece of stiff foam under the bottom of the tach for the track to keep it real solid.
Tach mounted over vent panel
Old Jun 23, 2003 | 11:46 AM
96 WS6's Avatar
Hehe thanks for the reply... I am going to try the install today. One question, whats a toggle bolt???
Old Jun 23, 2003 | 01:32 PM
The bolts you use to mount things in dry wall (sheet rock). The "toggle" is a little bar hooked to the nut, on a spring. You push the toggle through the hole with it up against the bolt. When it gets through the wall, it springs open and grips the wall from behind when you tighten the bolt.
Old Jun 23, 2003 | 01:48 PM
CamaroRob97's Avatar
i think its like a dry anchor....
Old Jun 23, 2003 | 02:13 PM
Bastardcat's Avatar
Toggle Bolt
Old Jun 23, 2003 | 04:34 PM
96 WS6's Avatar
ahhh i see... I'm going to try to screw it into the ducting under the vent. I have been trying to get a screw started but the windshield is so steep it's kinda hard... any suggestions on how I can get a screw started???
Injuneer
Apr 25, 2022 06:22 PM
Novo
Jun 14, 2016 02:58 AM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
