Need help. Car is backfiring and running poorly. Check Engine Light on also.
Old Jun 22, 2003 | 04:25 PM
97CamaroSS's Avatar
Angry Need help. Car is backfiring and running poorly. Check Engine Light on also.
My car has 59,000 miles on it. This past Friday, I went on a road trip and as soon as I left town, my "Service Engine Soon" light came on and was flashing for the whole trip. My car seems to have a loss of power and it is backfiring a lot. It backfires at idle too.
The car was running excellent before the trip. Could it be my Fuel injectors?
Any suggestions would be much appreciated because I would like to get this fixed before I have to travel back home.
Old Jun 22, 2003 | 05:53 PM
joeSS97's Avatar
Flashing=misfiring.I would get new plugs and wires.Odds are that will fix it.
Old Jun 22, 2003 | 05:55 PM
RRios8191's Avatar
Backfiring
Go get it scanned right away....it could be a number of things.
Old Jun 23, 2003 | 07:13 PM
97CamaroSS's Avatar
Took it to Auto Zone today. The guy said its not throwing any codes but the SES light is still flashing and the backfiring is horrible.
He said it could be the vacuum hoses.
Thanks for the help.
Old Jun 26, 2003 | 02:20 PM
97CamaroSS's Avatar
I'm gonna try and change the fuel filter today if it will quit raining. Hopefully this will fix it.
Old Jun 26, 2003 | 05:08 PM
97CamaroSS's Avatar
Well, I just changed the fuel filter and nothing has changed. I changed the spark plugs and wires about 8,000 miles ago, so I dont think its them.
I need some help guys. Please. Anymore suggestions?
Old Jun 26, 2003 | 06:01 PM
joeSS97's Avatar
Coil,ignition module,wires....one of them is the problem.Check under your hood at night with the engine running.
Old Jun 26, 2003 | 06:14 PM
jbird's Avatar
Could this be the dreaded OptiSatan on its way out? I would check your wires good first off, one of them may have been burnt by exhaust manifolds/headers, or one may have even not been on all the way, I've heard the wires on the opti are a little tricky to get on good. If one wasn't all the way seated maybe it's slipped off enough to cause a miss.
Hope this helps a little ---J.Bird
Old Jun 29, 2003 | 09:41 PM
97CamaroSS's Avatar
Well, finally figured out what the problem was. You guys were right, it was the wires. We took a closer look at the wires and one of them was almost burnt in half back behind the header where it was real hard to see. Replaced it, and my car is running great again Thanks for all the help guys.
Scott
Old Jun 29, 2003 | 10:15 PM
bad95z28's Avatar
wow, there's a stranger. glad you got the problem figured out. i guess the SS is still around. i haven't seen you in a long time.
bfmv13trivium
Jan 14, 2015 09:57 AM
ro2207
Dec 4, 2014 06:18 PM
blac94Z
Dec 2, 2014 12:09 PM
Jul 4, 2005 05:00 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
