What to use to get the pilot bushing out. ( I have grease, but what object fits)
Old Jun 19, 2003 | 08:38 PM
Lt1firebat's Avatar
What object fits tight enought into the pilot bushing hole, so that when you press it in, the grease won't keep comming out of the sides?
Thanks.
Old Jun 19, 2003 | 08:45 PM
Dave88LX's Avatar
Toilet paper and water.
Don't believe me?
http://web.camaross.com/forums/showt...hreadid=131481
Old Jun 19, 2003 | 08:46 PM
Z95m6's Avatar
i would try the toilet paper i have never gotten the grease trick to work the old man can make it work but not me
Old Jun 19, 2003 | 08:50 PM
Hotwire's Avatar
lmao, dude, I was in your same boat trying to pull the bearing in my s-10.
go to autozone and rent their pilot bushing puller for $20, hook it up to a dent puller and have it sitting in your hands in three whacks. i was under the truck for 4 hrs cussing that thing, got the puller, 30 seconds, no lie.
good luck.
Old Jun 19, 2003 | 09:02 PM
drewstealth's Avatar
I tried had the same problem you did. I bought the puller from autozone also but it didn't fit. So what i ended up doing was using a big bolt i had lying around in the garage. I then grinded it down until it was the same size of the hole with a good snug fit. Worked perfectly. I now keep it in my tool box for the next time i do my clutch.
Old Jun 19, 2003 | 09:46 PM
nateh's Avatar
Try a 1/4 inch drive extension with an 11mm (I think) socket on the end backwards. It just fits. The toilet paper trick worked with this setup.
PublicEnemy1
Apr 7, 2015 12:21 PM
BigWil
Mar 29, 2015 12:24 PM
Hurin
Dec 13, 2014 07:38 PM
bossco
Nov 29, 2014 10:18 AM
Camaro_Eric
Aug 8, 2002 12:21 PM
