ABS Problems, Someone Please Help
Old Jun 19, 2003 | 12:19 PM
satta3's Avatar
Unhappy ABS Problems, Someone Please Help
My car (95 T/A) keeps acting up. As I come to a normal stop the low trac light comes on and the abs pulses. If its not doing that its flashing an abs inop light at me. Then other times its normal. I was told that it could be the abs box and that there are some brass gears in it that tend to wear out? I thought it might be an abs sensor or something. If any of you guys have a clue, please help me out on this, its starting to dirve me nuts. Thanks.
Old Jun 19, 2003 | 01:41 PM
Sounds a lot like the way my ABS acted when the sensor in my Strange 12-bolt was not positioned correctly... as the car came to a stop, the sensor signal wasn't strong enough and the ABS would pulse as it lost the signal, taking an extra 5-ft or so to stop. Check the sensor on the differential for loose wire or corrosion. A faulty sensor will turn on the "ABS INOP" light as well.
1996LT1Z28
Apr 14, 2015 07:15 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
squarehead
Jan 15, 2015 07:02 PM
