Oil pan: Canton, Stefs, or ???
Old Jun 18, 2003 | 12:43 PM
10secz's Avatar
It looks like I'll never get my Stefs pan to quit leaking. I just finished the most careful and thorough in-car oil pan gasket replacement I can possibly do, and I think it's still leaking at the front and back half-round interfaces. So...
What other options are out there for stroker pans besides the winged Canton? This car does not get road raced or autox'ed so I don't need fancy baffling. And since it has a BMR cradle and no exhaust crossover pipe I could probably use a Vette pan.
Old Jun 20, 2003 | 11:49 AM
10secz's Avatar
So none of you guys are using anything besides stock, Canton, or Stefs oil pans?
Old Jun 20, 2003 | 12:03 PM
tubby's Avatar
LJ,
stay away from canton. look in the tech section and you'll see a buch of people (self included) that don't like them
Old Jun 20, 2003 | 01:01 PM
bowtiepwr's Avatar
Originally posted by tubby
LJ,
>Oh great I just bought a Canton pan .
What exactly is the problem with their pan ?
LJ I received your Impedance converter box today ... looks very good .
Thank you .
Old Jun 20, 2003 | 06:30 PM
97SS ragtop #077's Avatar
i've got a Milodon on my 385. it's a quart more capacity, but thats about it. no teflon, no extra windage....nuttin! Wish i had gotten something better....
Old Jun 21, 2003 | 01:22 AM
97 RedSS's Avatar
You can read my posts in the Tech section about my canton..
Cody
Old Jun 21, 2003 | 01:38 AM
JordonMusser's Avatar
West South Central Moderator / Special Guest
my canton has been good to me. I use sealant on the oil pan gasket tho.. lots of it
Old Jun 21, 2003 | 08:15 AM
bowtiepwr's Avatar
>this is for those who care .
from their site :
http://www.cantonracingproducts.com/...ace.html#15244
STYLE: 7-1/2" shallow, fully baffled for road racing, this pan was designed to fit in late model (82-92) F Bodies, (93-Up) F Bodies might require the steering rack to be lowered or the engine mounts shimmed. Makes a great late F-Body Drag Pan. Can be used with cross-over exhaust. Pans can be notched for steering clearance on a special order basis.
FEATURES: 3 Trap door baffles, removable one way screen windage tray with built in crank scraper, oil temp fitting, magnetic drain plug and, 20mm fitting for low oil warning sender.
SIZE: 7-1/2" Deep, 12" wide, 8-1/4" long sump has a 6 qt. system capacity.
STARTER: Works with stock starter.
PART #’S:
#15-242T pan for direct bolt-in, '93-97 F-Bodies.
#15-244 pan for pre-80 blocks with left side dipstick.
#15-244T pan for 86 and newer blocks with a one piece seal.
Old Jun 21, 2003 | 04:04 PM
zturbo's Avatar
Dan Olson motorsports oil pans. I had a stefs and it was fairly nice but i wanted the next step and they will make a pan for your needs and wants
Olson Motorsports.
Steven
realistyc
Jul 28, 2015 07:32 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
