Front Timing Cover Leak
Old Jun 14, 2003 | 01:50 PM
JOE96Z28SS's Avatar
My Z is leaking a drop at a time out of my FTC!!!! I see it's the front Oil pan seal and I wanted to know the easiest way to fix it!!! Oil pan or timing cover!! I installed it exactly how it said in the service manual when I rebuilt it, but I guess I obviously did somthing Wrong
Old Jun 14, 2003 | 02:52 PM
You need to be certain where the leak is and not maybe from a seal above. The oil pan goes on after the timing cover and it is possible to drop the front of the pan to fix a leak at the front where they mate.
Old Jun 14, 2003 | 03:07 PM
JOE96Z28SS's Avatar
I put the car on the lift Cleaned off the whole Front and Started it, It's coming out of the rubber seal taht is on the Oil Pan front. I put this on while the engine was still on the stand, I put RTV in the corners, Do I need it all the way through??
Old Jun 14, 2003 | 03:28 PM
I would think, by the rubbery compound the oil pan gasket is made of, you would not need any sealer. However, if it leaks then I guess you need some.
I used RTV on the front of mine when I did my cam swap (because it had started seeping a little before the swap and I did not want to have to go back and seal it again). I used brake cleaner to get all the surfaces free of grease and smeared sealer on each side of the front. No leaks so far.
Old Jun 14, 2003 | 05:42 PM
JOE96Z28SS's Avatar
so I can just take off the front timing cover? I'd really hate to loosen up the oil pan, or is it easier?
Old Jun 14, 2003 | 06:26 PM
If you don't loosen the pan, you will probably rip the oil pan seal and then have to replace the whole thing. Don't make a bad situation worse.
Old Jun 14, 2003 | 06:29 PM
FastZinTennessee's Avatar
Yea I ripped my oil pan gasket while pulling the timing cover off. I put RTV all over it and reassembled it as best I could. It's gonna be a miracle if it seals. If it leaks though, I'm paying someone to fix it. If I have to work on this car one more day I'm gonna have a mental breakdown!!!!
John
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
