Steel or Chromoly LCAs?
Old Jun 9, 2003 | 12:03 AM
94 CAMRO Z28's Avatar
I know the chromoly should be a bit lighter, and wont rust, but whats your opinions? I think im going with the BMR steel tubulars for $109, or the chromos for $139. Worth the extra $20?
Aaron
Old Jun 9, 2003 | 12:06 AM
Larnach's Avatar
Aluminium rod ended
Old Jun 9, 2003 | 06:10 AM
mc63's Avatar
The cromoly are much stronger and worth the extra money.
Old Jun 9, 2003 | 06:19 PM
Larnach's Avatar
How are they much stronger... they use a thinner walled tubing, thus it is the around the same strength, only a reduction in weight, that is why chrome moly is used in roll cages and chassis and such.
Unless your cutting 0.75 60' times, aluminium arms will work with the proper wall thickness.
Old Jun 9, 2003 | 06:27 PM
I know that chromoly tubes are slightly thinner to reduce more weight, and they are suppose to have the same strength... Does anyone know just how much lighter they are? If its only a few pounds a piece I'll save my $20.
Aaron
Old Jun 9, 2003 | 06:30 PM
Larnach's Avatar
Maybe 5lbs... with "my" aluminium design, you'll save about 2.5lbs over stock... and retain more strength, and it has rod ends. Much better for suspension articulation than polyurethane which has no give to it.
Old Jun 9, 2003 | 06:40 PM
You sure about the strength of aluminum. Its so stiff/rigid it tends to weakin itself over time.
Aaron
Old Jun 9, 2003 | 06:52 PM
Mindgame's Avatar
Aluminum does not have the fatigue resistance to make a good LCA. That's why everyone uses 4130 chromo and steel.
I'd go chromoly.
-Mindgame
Old Jun 9, 2003 | 11:10 PM
Larnach's Avatar
OK... well I'll hold you to that after I install them and run them for several thousand miles
Aluminium is stiff, not strong, there is a great difference, same goes with composites.
Old Jun 10, 2003 | 12:14 AM
rskrause's Avatar
Moderator
Mild steel is fine. Has anyone ever bent the stock stamped pieces? So strength isn't an issue. Saving a couple of pounds on a 3,500+lb car? Not a high priority in my book.
Rich Krause
Old Jun 10, 2003 | 07:25 AM
Larnach's Avatar
A few pounds of unsprung weight in our live axle rear suspension cars = slightly smoother ride.
The stock stamped peices flex considerably.
13qtr
Oct 28, 2016 08:11 PM
karpetcm
Sep 29, 2015 10:08 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
karpetcm
Aug 14, 2015 03:02 PM
