how to change pass side o2?
Old Jun 7, 2003 | 02:35 PM
got_hp?'s Avatar
ok........before i goto the PITA task of dropping the stock y-pipe.............is there an easier way to replace the passnger o2 sensor?
i cannot fit my arm or wrench in from the top, even if i remove the alt.
i have factory ypipe and manifolds.
i do not have the special o2 socket, and have no ride to go get one.
looks like my only choice is dropping the y-pipe, unless someone knows a better way.
i sprayed some stuff on the bolts to loosen them........now im waiting a few hours to give them a try.
Old Jun 7, 2003 | 02:52 PM
1995redZ28's Avatar
same thing happened to me. could NOT get it loose if my life depended on it!! i ended up dropping the y-pipe. took maybe an extra 20 min. but def. made the job a LOT easier!! once the pipe is down, the o2 is right there. just make sure you spray the bolts for the y-pipe too if u decide do drop it! good luck!
oh and if you can somehow get a hold of a o2 socket, it makes the job 100X's easier!!!
Old Jun 7, 2003 | 03:19 PM
got_hp?'s Avatar
well im waiting for the penetrating oil to loosen up the y-pipe bolts.........then see if i can get that ****er off..........it looks like it will be really hard to reach/turn the bolts on the passnger side header/ypipe meeting
Old Jun 7, 2003 | 05:29 PM
1995redZ28's Avatar
hey if i remember correctly... take out the starter!!!! its only 2 bolts, and it frees up TONS of space. that way you can reach the bolts! trust me i know, i just removed the y-pipe to install my hooker lt's this weekend! now i dont have to worry about the rusty thing anymore!! but be careful not to snap any of the bolts!
Old Jun 7, 2003 | 06:02 PM
got_hp?'s Avatar
well, i amazingly was able to remove the ypipe without breaking anything..................damn those bolts were stubborn.
anyway.......put everything back together.........how tight do i have to get those ypipe-to-header bolts...........there really isnt much room to get good leverage.
Old Jun 8, 2003 | 12:06 PM
Laymaster's Avatar
My Y-Pipe was easy to drop.
All I did was spray it with PB Blaster from NAPA (which prolly did the trick) and then I used that electric impact gun (the one everyone calls a joke) which is originally intended to be used to do lugnuts, you can put on standard sockets and that dropped my Y-Pipe real quick!
DirtyDaveW
Dec 1, 2016 05:37 PM
armedtrigger
Feb 24, 2015 08:30 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
